cam chain tensioners
Old Apr 3, 2009 | 12:53 PM
drewhd64's Avatar
drewhd64
Stage II
Default cam chain tensioners
Did anyone change their tensioners and if they did did they change the inner and outer bearings,and did they buy the bearing installing tool and the cam lock tool. Also did they go to the gear drive or did they do the tensioners. thanks Drew
Old Apr 3, 2009 | 01:05 PM
kromdom's Avatar
kromdom
drew,
not sure if you already done a search about this topic as it has been discussed at length. here's something to get you started: https://www.hdforums.com/forum/searc...archid=1779211
Old Apr 3, 2009 | 03:13 PM
HDRider2002's Avatar
HDRider2002
i replied briefly on another thread as well drew, yes i did replace the cam bearings mainly because i was replacing the cam itself. I dont' think you'd have to replace teh bearing if you are just replacing the cam chain tensioners. Given i would be having the cam out, just made sense to spend the $10 to replace the inner bearings (outer bearing came with the cams).
As for tool purchase, i'm having the work done, so i'm assuming he already has the tools necessary, and will utilize them. For the price of the tools, seems extravagant to purchase them if you aren't planning on using them more than a few times. There have been posts here in the past of places that "rent" the tools if you are so inclined to go that route.
Old Apr 4, 2009 | 03:42 AM
Big Peter's Avatar
Big Peter
I took the chains and tensioners out
and went to gear drive.
It's great !
http://www.sscycle.com/modules/instr...ds/51-1047.pdf
Peter
Old Apr 4, 2009 | 04:02 AM
hpfatboy's Avatar
hpfatboy
It's great !
Peter
2nd that, one of the best mods. i ever made.
Old Apr 4, 2009 | 04:16 AM
xxxflhrci's Avatar
xxxflhrci
yes, yes, no, no, yes.
Ozark Bob
Jan 21, 2025 10:51 PM
matt_m_72
May 27, 2019 07:50 AM
LeFat1
Exhaust System Topics
26
Apr 28, 2013 01:21 PM
jrgreene1968
Oct 3, 2012 08:22 AM
rags
Oct 31, 2009 02:34 AM
