AMP Multilock Connector Tool??
Old Apr 8, 2009 | 05:05 PM
Coffeeman's Avatar
Coffeeman
Default AMP Multilock Connector Tool??
I need a tool for connecting the AMP Multilock Connectors. The HD tool (HD-41609) for mounting AMP Multilock Connector pins is a dealer-only tool---and probably too expensive. Does anyone know of a different crimping tool (hopefully affordable) that will crimp the AMP Multilock Connector Pins correctly? If you have a tool that you know will work, please provide a website, part number, etc., I would appreciate it. Thanks.
Old Apr 8, 2009 | 05:16 PM
HDV-GLIDE's Avatar
HDV-GLIDE
You can do it with a pair of needle nose pliers if your careful. I have done it numerous times on my V-Rod and now SG and I may have only ruined one pin. As long as you use the correct gauge wiring, you should have no problem. The pins only go into the connectors one way, so look how the old ones came out for a reference.
I used a little solder to seal the wire into the pin and then gently closed the two tangs down onto the wires insulation to secure it.
If it worked for me, it should work for everyone......
Old Apr 8, 2009 | 06:31 PM
MickeyB's Avatar
MickeyB
+1 I also looked into buying the tool. Way too expensive for me. I used needle nosed pliers and a regular crimp tool and it worked out ok. You may have to trim a little bit off the 'wings' of the pin that go around the insulation. Other than that, it worked for me.
Mike
Old Apr 8, 2009 | 07:32 PM
Harleypingman's Avatar
Harleypingman
You may find this articles helpful and the tool used can be purchased from Great Plaines Electric for $25:
http://www.aeroelectric.com/articles.../matenlok.html
peddler
Feb 6, 2014 08:45 AM
ryderbiker
Mar 10, 2012 09:21 AM
voudoujoe
Electrical/Lighting/Alarm
Feb 7, 2012 01:18 PM
GrampsWyatt
Oct 29, 2007 03:03 PM
ronyd
Oct 25, 2007 11:14 AM
