decel pop
Old Apr 8, 2009 | 09:20 PM
road king jay's Avatar
road king jay
Default decel pop
I have a 03 road king with big bore kit(95inchs) big air sucker and just swapped the pipes yesterday from stock to a set of screaming eagle. All i did was swap the slipons and I took the bike out for a test ride and it pops. Harley says becasue I have the download I don't need a power commander. Am I going to damage my bike by not adding on a power commander or is bike going to be fine just have a pop everytime I let off the throttle? Please help, love the bike don't want to fu** it up
Old May 23, 2009 | 09:26 AM
erbdaddy's Avatar
erbdaddy
get a commander needs to be mapped and dynoed
Old May 23, 2009 | 11:10 AM
kromdom's Avatar
kromdom
most common cause for decel pop is an exhaust leak. good to place to start checking (cheaper too )
Old May 23, 2009 | 12:54 PM
bdaug50's Avatar
bdaug50
I can honestly say I have no idea what I'm talking about but the people I talk to that actually do know what they are talking about would recommend you get some type of fuel management add on.
Old May 23, 2009 | 01:35 PM
TheBagger's Avatar
TheBagger
I could never get my bike to stop popping with the HD download. I know it was running lean and seemed hot. I finally got a Power Commander and NO MORE POP!
Old May 23, 2009 | 01:48 PM
StreetGlideMedic's Avatar
StreetGlideMedic
Most people I know with a Harley Download...have a decel pop! How do they get rid of it??
Getting A PC-V! Or one of the other Commanders. They are plug and play...easy to install and you'll enjoy the benefits!
ride Safe, Mike
Old May 23, 2009 | 03:56 PM
atrain68's Avatar
atrain68
I recently went over my SG looking for exhaust leaks which is one of the culprits of decel popping. The short version:
Use new TORCA clamps ($6 each) along with a generous amount of Ultra Copper Silcone. Torque clamps to specs and problem solved.
Regarding fuel management, every bike is different, so I recommend calling FuelMoto and order a Power Commander. Fuelmoto will help get you the right map plus you will have the added benefit of being able to fine tune later.
Old May 23, 2009 | 04:03 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Get a power commander and a dyno and your pop should dispappear.
Old May 31, 2009 | 05:10 PM
kminners's Avatar
kminners
Stage I
Hi,
I have the same bike, just got the big bore kit. My bike, since it was new, has always popped on decel. I had the Stage 1 kit installed at purchase. Did you get the Power Commander? If so, did that solve the problem? Thanks.
Kory
Old May 31, 2009 | 05:23 PM
rbabos's Avatar
rbabos
You are not likely hurting anything with the popping but solve it you need to richen the idle and a bit above idle to stop it. Fuel managenment is the only solution. As mentioned check for exhaust leaks first before throwing more money at it.
Ron
Craigmac
Apr 21, 2013 10:12 PM
JakeInMa
Sep 13, 2009 08:12 PM
mcdaniel52761
Jul 13, 2009 07:20 PM
DaveGTR
Jan 15, 2009 09:16 PM
2006RKCI
Sep 12, 2007 05:21 AM
