2003 ultra and ipod
Old Apr 15, 2009 | 10:16 AM
mickeyboy's Avatar
mickeyboy
Stage II
Default 2003 ultra and ipod
can i hook an ipod up to my 2003 ultra stereo using the cd input jack? if so, what do i need? thanks.
Old Apr 15, 2009 | 10:38 AM
dawg's Avatar
dawg
cord with 3.5mm male jacks on each end
Old Apr 16, 2009 | 08:21 AM
mickeyboy's Avatar
mickeyboy
Stage II
Default Thank you.
Thank you kindly, Sir.
Old Apr 16, 2009 | 08:46 AM
Theakerr's Avatar
Theakerr
I also use a RF transmitter hooked into the cigarette lighter, not to play the i-pod since the 1/8th direct hook=up is much better - but to keep the i-pod charged. I found that to get reasonable sound level out of the radio I had to use a fairly high output setting on the i-pod. Also, I found that unlike listening with the headphones that requires no switching on the i-pod, I had to switch (click) it on when using the aux input. I nearly gave up on the i-pod and the direct input because I just couldn't get it to work. Based on the charging system I was suspicious that you had to use an apple specific cable. Then by accident I got it to work one day and then was able to back engineer it. Note this problem may be specific to certain i-pods only, i have an early nano
Old Apr 16, 2009 | 08:58 PM
GzrGlide's Avatar
GzrGlide
I use a Monster brand charger, FM transmitter for charging and the 1/8th cable to get the tunes thru the stereo. Works great even with my 1st gen Nano. Never failed me.
Old Apr 16, 2009 | 09:06 PM
Lawdawg's Avatar
Lawdawg
I don't have an ipod, but I do use my satellite radio. I use the radio kit with a windshield bag, I also use the cigarette lighter with the input on the radio. So yes it does work, just play with it.
Old Apr 16, 2009 | 11:00 PM
gilbos440rt's Avatar
gilbos440rt
Plug in and go!
larry5h
Sep 17, 2008 10:04 PM
VROCK SE
Aug 2, 2006 03:46 PM
ULTHD
Feb 11, 2006 11:20 PM
Pignose
Jan 18, 2006 10:25 PM
ClassicBob
Mar 4, 2005 01:15 AM
