Audio Question?
Old Jul 19, 2006 | 06:11 PM
larry5h's Avatar
larry5h
Default Audio Question?
Does anyone use an i-pod or mp3 player that plugs into the radio on the Ultra Classic?
Any advice would be greatly appreciated. Thanks.
Old Jul 19, 2006 | 06:14 PM
Landfill_Tim's Avatar
Landfill_Tim
Default RE: Audio Question?
I'm here to add to you question. I have an ipod. I want to use it on the SG, how do you have them mounted and are you just using a patch cable?
thanks.
Old Jul 19, 2006 | 06:19 PM
bonzo2's Avatar
bonzo2
When I use an IPOD on the ultra I just pace it into the lower fairing and use an audio out cable that plugs into the AUX port on the HK radio. make sure your speakers are turned on and then press the button on the right handlebar in until the radio switches to AUX and your all set.
Old Jul 19, 2006 | 06:22 PM
HD Jake's Avatar
HD Jake
I use my Ipod on my Ultra, I just got a small patch cord, plug it into the headphone jack on the Ipod and into the Aux plug.
Perfect, hours of MY Music
Old Jul 19, 2006 | 06:42 PM
Baldman's Avatar
Baldman
Look just to the left of my right grip...that is my MP3 player. I love it.
Take care,
Baldman
Old Jul 19, 2006 | 06:45 PM
hangnman's Avatar
hangnman
Will a xm roady II plug in the aux?
Old Jul 19, 2006 | 06:47 PM
WEELEE's Avatar
WEELEE
2nd Gear
WWW.RAM-MOUNT.COM
ALL KINDS OF MOUNTING SYSTEMS HERE
Old Jul 19, 2006 | 08:54 PM
Slyde's Avatar
Slyde
I run a Sony MP3 player with a patch into the front of my 00' Ultra. Works great so far.
Old Jul 19, 2006 | 11:29 PM
SpikeCT's Avatar
SpikeCT
Ok, So I was thinking about this today. I have a Starmate mounted and I use my I-Pod also. At this time I use the FM modulator for the Satellite and Aux for the I-Pod. This is what Im thinking of doing. Im going to buy another switch and install it next to the Spot switch. Then I'll run and Aux cable and split it between the two..... Ok, As im typing this I might not be able to use a stock switch but I would install a small switch and hide it..... Ok, I need to think about this and sketch a quick schematic...... I'll let you all know but it will happen so I can get the best of both worlds. Oh, As for the I-pod I place it in the winshield pouch.
Old Jul 20, 2006 | 01:05 AM
TheRealCopey's Avatar
TheRealCopey
ORIGINAL: SpikeCT
Well, you could do that... or you can go to radio shack, get a stereo headphones Y adapter and just plug them both in. All you would have to do is leave whichever aux device you are not using turned off.
