YES! Another Garage Door Opener Thread
Old Apr 16, 2009 | 12:33 PM
notlost_nc's Avatar
notlost_nc
nice job.
Old Apr 16, 2009 | 12:53 PM
HauerMG's Avatar
HauerMG
Originally Posted by slime_dog
I bought a "replacement" odometer reset switch from the dealer. It is a momentary switch with a rubber, weatherproof, cover. I mounted it on the dash and wired it to my remote. The switch and rubber cover was about $15 from Harley. I don't remember the part # though - just ask at the parts counter.
The switch has two leads that come off the end. Find the circuit, on your garage door controller's circuit board, that you have to close and solder your wires from the odometer reset switch there.
Switch P/N : 67854-98
Boot P/N : 67880-94
Old Apr 16, 2009 | 04:39 PM
jagerbomb's Avatar
jagerbomb
Originally Posted by jdreed520
Cool i have the same remote......and i think i will do that this weekend.....but can you post the part number of the switch please
ck out post #366 https://www.hdforums.com/forum/touri...o-save-37.html
Old Apr 16, 2009 | 04:53 PM
awmllc2000's Avatar
awmllc2000
clean install!
Old Apr 16, 2009 | 08:14 PM
oricko's Avatar
oricko
07-18-2007, 06:49 PM
128auto
RE: My $25 remote control garage door opener
I am rewriting this full instruction on “How to rewire the garage door opener” requested by ******.
1. Find an automotive 4 or 5 terminals relay, it can be found in any auto parts store. (see picture 1)
2. Open the case of the Garage door opener, you will find the switch on the circuit board, heat up the solder and remove the switch, put 2 wires on each circuit and resolder them. (see picture 2)
3. Make a slot on the side of the opener case, run the 2 wires through, tag them to the relay terminal 30 and 87.
4. Ground relay terminal 85 to the chassis or good ground.
5. Run the last wire from terminal 86 to your source, it could be a momemtary switch, high beam switch or horn switch, in my case, I wired it to my horn switch.
6. Test operation, remove the battery side cover, I mounted the opener on the left side of the battery above the battery positive cable, the relay sits below the positive cable, I used azip tie to secure them.
Hope the instruction is clear. Alex
Picture 1
Picture 2
Picture 3
Wiring diagram
__________________
If it aint broke, fix it till it is.
Click here to view my photos www.128auto.com
06 FLSTFI/06 XL1200L(SOLD)/08 M. Benz ML320CDI
This is the garage door opener set up I used. As you can see it was done originaly by 128 aUTO
soulpatch
May 27, 2019 01:14 AM
Am4wag
Jul 1, 2013 05:12 PM
alkrisma
Apr 8, 2011 09:57 PM
Steve_in_FL
Aug 25, 2008 10:34 PM
nmfxstc
Jun 27, 2005 04:00 PM
