Just adjusted my clutch per the service manual. Loosened the cable, turned the clutch adjustment screw till seated lightly and backed out 3/4 turn. Tightened jam nut.
Here is my question. Seems like the clutch now engages much later in my release than previously. In other words, the friction began 1/2" away from the grip before, now friction begins 3/4" away from the grip.
I'm confused. I loosened the clutch cable till the lever was against handgrip. performed the adjustment in the chaincase then tightened the cable till I had 1/16-1/8 of play in the lever.
Seems like I somehow did things backwards. Prior to the adjustment, the lever was vibrating at cruise. Now lever is tight, however it seems the clutch wants to engage further away from handgrip than previously.
Not room temp, garage temp. Was about 55 when I did it.
Then I'd agree with sparky; only back off the adjustment screw 1/2 turn. Also, my interpretation of "lightly seated" (as stated in the service manual) seems to be a little different than most people... To me, "lightly seated" doesn't mean "lightly touching". If I'm seating a seal, for example, I'm making sure that it is nice and snug where it's supposed to be. So "lightly" seated to me still means that it's making a healthy amount of contact. In adjusting HD's clutches, that theory has worked for me.
am I missing something in the post ?? You do know there are Two adjustments for the clutch - the 1/2 turn is AT under the Derby cover - the 1/16 is at the clutch lever.
Friction point should be higher. You did it right. It should engage further than the handle. Unless I am reading your post wrong and all the others, when you squeeze the clutch all the way in, it takes a longer throw to engage? If that is what I am reading, the clutch adjustment went right.
