I am helping a friend with his fuel injected 2001 Ultra that won't start. It has been sitting for 5 years and most of the gas has evaporated from the tank. We put in fresh gas, a new battery and attempted to start with no luck. The only way the bike will fire off is when we spray starting fluid into the throttle body. I am thinking that the electric fuel pump may be stuck/bad. All fuses look good. Any other thoughts/input from the forum would be appreciated. Thanks!
Fuel pump not running at all and has 12 volts while cranking. Ordered new pump and filter with hope that that is the only problem. Thanks to all for the input.
I have used Techron fuel injectoion cleaner in some of my previous carb fuel system bikes. It prevented me from having to remove the carbs and do a full clean which is a PITA.
You can also check the full pump relay.......it might be bad.....it should have 12 volts all the time. But it could be a bad pump. Also make sure you buy the console gasket.
