I noticed that the model they show for the 2009 Street Glide comes in the color of my bike (pewter pearl) - HD # 79071-09CHH.
Can this unit be used on a 2009 RKC as well, or not?
It doesn't appear the the Tour-Pak for the Road King Standard (which I assume will fit the RKC) is available in the color I need as pewter pearl was not a color option for the standard.
Or, can HD paint the RK Tour-Pak my pewter pearl?
Bottom line, I don't want the leather Tour-Pak, I want the hard shell version.
This is so confusing!
Thanks in advance,
Brad
The models for the Street Glides have an antenna mount on the back left, and a small hole in the front left bottom corner to route the antenna wire through. If you don't mind that, no reason you couldn't use it.
