Brakes
Old Apr 23, 2009 | 11:46 AM
spaug's Avatar
spaug
Stage IV
Default Brakes
I have a 04 FLHTI. The front brakes have a constant scrapping sound. The sound disappears after applying the front brake. THe pads looks new and I am not seeing any unusual wear on the pads or rotor. Took the dealer and they said everything is ok that some brakes just make that sound.
any suggestions?
Old Apr 23, 2009 | 11:54 AM
ckgdrums's Avatar
ckgdrums
Yep, my 07 makes that sound but I can only hear it when I'm rolling it out of the garage.
Old Apr 23, 2009 | 12:04 PM
riteway's Avatar
riteway
Default Welcome to HDF!!!!!!
My 04 does same....I have found that brake cleaner seems to help.spray pads, drive short distance,repeat(Be careful wet pads DONT grab well!!!)....seems to help...some guys have had great luck with aftermarket pad,i have not changed mine from stock yet.Good Luck..R.W...Also try a search!!!
And WELCOME....
Last edited by riteway; Apr 23, 2009 at 12:05 PM. Reason: Forgot to welcome!!!!!!!!!
Old Apr 23, 2009 | 12:29 PM
skratch's Avatar
skratch
when you release your brakes, the brake pads will move away from the rotors far enough that there is no pressure. consequently, that means that they are actually touching them very lightly, hence the noise. nothing to be worried about unless your pads are still applying pressure, then you could have a stuck piston. and that needs to be taken care of asap.
Old Apr 23, 2009 | 03:42 PM
SQUEEKY06's Avatar
SQUEEKY06
Stage IV
I got a 06 streetglide , same ! my bro's say here comes squeeky. I took it in to get looked at , they said its all good , I have only 4000 miles , please help !
Old Apr 23, 2009 | 11:06 PM
spaug's Avatar
spaug
Stage IV
When I took mine to the dealer to get them checked they flipped the rotors around and the squeaking stopped, but the scrapping continues.
Thanks for all the input. I know that the pistons are not sticking so I'll try spraying them
Thanks again
Old Apr 23, 2009 | 11:11 PM
Towboater07's Avatar
Towboater07
I only hear the scraping when the engine is not running, if I roll the bike.
miketv84
May 30, 2023 12:10 PM
see22ds
Jun 23, 2014 01:27 PM
95yj
May 27, 2011 01:03 AM
fixedmlc
Aug 25, 2009 11:11 AM
my2004harley
Feb 21, 2009 09:56 PM
