Help with Diagnosis needed
Old Apr 28, 2009 | 07:50 AM
mainshaft's Avatar
mainshaft
I had the same type noise on my 00EGC last summer, it eneded up being a bad front motor mount.
Old Apr 28, 2009 | 07:55 AM
eddie31770's Avatar
eddie31770
Hmmmm. Thats interesting as I think my bike vibrates way too much. I know they are supposed to but.....
Ok so I will have him check it and mention motor mount and exhaust. Any other ideas?
Old Apr 28, 2009 | 08:13 AM
rjmac53's Avatar
rjmac53
let us know what you find out....will be good to know for future reference...good luck
Old Apr 28, 2009 | 08:22 AM
eddie31770's Avatar
eddie31770
I absolutely will do that.
Old Apr 28, 2009 | 08:23 AM
mainshaft's Avatar
mainshaft
My bike also vibrated more than normal, I did a full vehicle alignment in my garage and it's as smooth as can be. I had to adjust both motor alignment links, and it is night and day the difference, it is very easy to do. Good luck.
Old Apr 28, 2009 | 08:29 AM
eddie31770's Avatar
eddie31770
Excuse my ignorance but what exactly is a full vehicle alignment and how is it done? Motor Alignment links?
Thanks
Old Apr 28, 2009 | 08:40 AM
molsen's Avatar
molsen
If this noise is something new recently I would suggest going over the exhaust bolts, heat shields clamps and look for any rubbing from the floor boards to the heat shields. Also, check the rubbers where the mufflers are in the back. I know you said it sounded like it was coming from the front, but it would not hurt as well.
Old Apr 28, 2009 | 08:44 AM
eddie31770's Avatar
eddie31770
Great suggestions. And these are things I can acutually do myself
Old Apr 28, 2009 | 09:06 AM
Pacemaker's Avatar
Pacemaker
I also had the chirp noise coming for the front end, it took me a long time to figure out what was causing it. As it happen more often I was able to find it. It turned out to be the tongue for the seat that slides into the frame. When I would accelerate and my body weight shifted back, it would pull the seat up and the tongue would rub against the frame and make the chirp noise. This may not be what's happening to you, but check it out....Good luck.
Old Apr 28, 2009 | 09:15 AM
eddie31770's Avatar
eddie31770
Ha. Thats an interesting suggestion. I guess I could just spray some WD on the toungue and see what happens. what was your solution?
