Neutral light always on
Old Apr 29, 2009 | 10:43 PM
williebig's Avatar
williebig
Stage I
Default Neutral light always on
New Bike, 09 Road King Classic, 1000 miles. Tranny light stays on no matter what gear I'm in. Any ideas?
Old Apr 29, 2009 | 11:08 PM
sbergerson's Avatar
sbergerson
First idea: 1000 miles.....Bring it to the dealer.
If you like DIY, locate the neutral sensor on the top of your transmission, visible from the right side of the bike. Remove the two 90 degree wire connectors from the sensor, and test the continuity of the sensor. Should be open in gear and closed in neutral.
If the sensor is working properly, then the wires are probably shorted somewhere.
If the sensor is not working properly, you can remove it and see if the little ball on the end is stuck. Maybe you can get it working. Otherwise you can replace it.
Hope this helps some.
Steve
Old Apr 29, 2009 | 11:58 PM
RenoGlide's Avatar
RenoGlide
My 07 SG did it from the day I picked it up new in Sept 06 and has been fixed under warranty 2 times. The last one lasted about 9 months so when it went out again 3 weeks ago, I stopped by the dealer. I learned theres a Serv Bulletin on it & a newly designed switch. Dealer couldnt get me in anytime soon but since I know all of them, I said Id do it & they gave me the new switch. ... easy job
Yours is new, Id take it back
Old Apr 30, 2009 | 12:15 AM
vtwin1340's Avatar
vtwin1340
Warranty issue, take it in.
RockyMtRK
2014-2024 Touring Models
Aug 14, 2015 02:46 PM
Rammer
Jul 18, 2009 07:27 PM
ext1bab
May 29, 2007 09:07 PM
Ultraman07
Feb 21, 2007 08:55 PM
texasjuan
Oct 24, 2006 01:36 AM
