Electrical Problem please help
2006 SG with a delphi alarm system with siren, was installing my in dash nav/dvd and to do this i ran a extra positive wire with 30 amp inline fuse and a negative, got everything hooked up and wanted to make it where the radio turns off with the key, i did not cut any wires on my bike what so ever, all i did was peel back some of the insolation on the ACCESSORIES wire which is red and gray. After having some issues with the lighting of the lcd and the lights on the new radio i took it off, so now my bike is completely back to stock, no radio fairing and all is still off. my bike will NOT start or light up what so ever no, but i came to figure out it will ONLY IF I HOLD THE NEW POSITIVE WIRE TO THE ACCESSORIE WIRE where i peeled alittle piece of insolation off. At that point it will turn on like normal and fire up and run, only thing is... when i turn the switch to the off position my tach and speedo light stay on and if its in off mode and i disconnect and reconnect battery i can hear the fuel pump come on and off EVEN THOUGH ITS OFF POSITION. Seems like im by passing something but can figure out what, i have checked my fuses under fuse box. ANY HELP I GREATFULLY APPRECIATE AGAIN SORRY FOR RAMBLING. By the way its a 1025n eonon dvd navigation
EDIT: heres the one I have used before. read it a few times before you do it, its confusing... TSSM Reset
if that gets deleted for being another board, PM me and ill get it to you.
