Hesitation / Stall when warm
Old May 6, 2009 | 02:40 AM
kwb's Avatar
kwb
Default Hesitation / Stall when warm
Hello - I have a 2009 Road King Classic with Rinehart slip-ons, HD SE Air cleaner and a PCV.
My bike runs great, except when it gets a little warm out and I stop at a light. When I go to take off it sometimes will die or hesitate when I try to crack the throttle.
I tried reflashing the PCV with the download from FuelMoto, but it didnt seem to help.
It's only when its warm, but I dont think the bike is getting hot enough to switch to "Power Management Mode". It seems that the mixture isnt correct once the engine is good and warm and at a start from idle...
Any ideas?
Thanks!
Old May 6, 2009 | 02:50 AM
Captain Itch's Avatar
Captain Itch
Sponsor
cant answer your question but I do have a PCIII ON A 06 RK with the same symptom,but is not happening all the time. Bike has 20,000 on it.
My first thought was the fuel management
Second maybe a dirty injector
Third intake leak
Ok where are the motorheads?
__________________
www.Captain-Itch.com
Old May 6, 2009 | 04:43 AM
REVDOGGY's Avatar
REVDOGGY
Any ideas?
Thanks!
I'm also having the same issue not good. Please keep me updated and if I get a answer first I'll let you know as I'm going to the dealer today.
Old May 6, 2009 | 05:42 AM
kwb's Avatar
kwb
Rev - Which fuel management system are you using? (SERT, PCV, ect...)
Old May 6, 2009 | 06:53 AM
nisalada's Avatar
nisalada
Mine will hesitate as well. I just associated it with the temp control and rear cylinder cut off or perhaps to the TBW. I don’t even notice it anymore. It would be interesting to see if the new 08/09 TBW Thundermax ECU will take care of it... whenever it is finally released to the public!
Old May 6, 2009 | 07:28 AM
crump's Avatar
crump
5th Gear
Had same issue, installed Power Commander. Had fuel/air perfectly tuned in and in 2+ years not even a hint of hesitation.
Old May 6, 2009 | 10:33 AM
bobbydeuce's Avatar
bobbydeuce
I have had this happen to me a few times, I'm wondering if this is an issue with the PCV and 2009 EITMS being compatible. After the EITMS kicks in I have to really ease into the throttle or it stalls, or sometimes just dies.
Old May 6, 2009 | 11:20 AM
kwb's Avatar
kwb
It's kinda dangerous too - when you're at a light and it turns green and the bike stalls. I'm always affraid of getting rear ended by the car behind me....
Old May 6, 2009 | 11:28 AM
TNTHarley's Avatar
TNTHarley
I'm no expert on this stuff but when I had the problem I was told it was the throttle position setting being done while the engine was not hot enough. I re-did my throttle position setting procedure and all was well.
Old May 6, 2009 | 01:15 PM
REVDOGGY's Avatar
REVDOGGY
Power Commander. They reset my throttle so we will see. I still don't understand it.
