HD Adjustable Backrest- need HELP
Old May 9, 2009 | 04:07 PM
Lightngsvt2's Avatar
Lightngsvt2
Default HD Adjustable Backrest- need HELP
So its pretty much a given that the directions that come with the kit are worthless, so Im pretty much trying to install without them. Can someone send me, or post a picture of where the bracket with the handle is mounted and where the cable runs? I must be as dumb as I look because I cannot figure out where to mount the damn thing!
Old May 9, 2009 | 04:16 PM
Road Ranger's Avatar
Road Ranger
Do a search for rider adjustable back rest. I believe there is another thread that was started recently that covered the same question you're asking.
Old May 9, 2009 | 04:36 PM
cruise_carter's Avatar
cruise_carter
Chuck, do you have the instruction sheet?
Old May 9, 2009 | 04:48 PM
Lightngsvt2
I do have the instructions, but for some reason I just dont see where the handle is supposed to mount?
Old May 9, 2009 | 05:05 PM
Plow64's Avatar
Plow64
I'll give it a try and post a pic.....
Man, I need to give that bike a good scrub down...
Attached Thumbnails HD Adjustable Backrest- need HELP-hydraulic-seat-mount.jpg
Old May 9, 2009 | 05:13 PM
dgriffith's Avatar
dgriffith
While you are at it, put a couple of washers under the front bracket where it bolts down. It will help tilt it back some. It's been discussed here over the years. A couple wil do the trick.
Old May 9, 2009 | 05:31 PM
Scooter_092196's Avatar
Scooter_092196
I just put my bracket in a vice and bent the front "tab" a tad to give me the same affect as adding the washers...
Old May 9, 2009 | 07:06 PM
Lightngsvt2
Thanks for the pic Plow64!
I'll try it out and keep the washer mod in mind if I need some more angle on the backrest.
Old May 9, 2009 | 07:12 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
also be very carful when tightening the bolt the band that holds the cruise cable will try and spin and will twist up the cable (dont ask me how I know)
Itzameeh
Touring Parts
Feb 12, 2019 11:27 PM
martinjd
Jun 9, 2014 07:22 PM
46u
Jun 4, 2011 04:20 PM
tmoreau
Feb 19, 2008 07:07 PM
mhud
Dec 10, 2007 08:02 PM
