Stereo Experts Needed
Old May 15, 2009 | 10:29 AM
Chula's Avatar
Chula
Thanks for the help! I have another question. Change all 4 speakers or just the front 2? Can an amp power all 4?
Old May 15, 2009 | 10:34 AM
Pork-Chop's Avatar
Pork-Chop
+1 on firecap, he is good to deal with
Old May 15, 2009 | 10:43 AM
89FLHT's Avatar
89FLHT
Short answer is yes- you could wire all for speakers in parallell off of the 2 channel amp - (I'm doing this exact same thing on my bike since I'm running 4 speakers in the fairing).
I assume that the 4 speakers you'll be doing is 2 in the fairing and 2 on the tour pac?
FireCap can also hook you up with a ARC 4 channel amp that is just a little bit larger than the 2 channle amp and could drive all 4 on seperate channles.
He's the expert - I'm definitly not - but I'm a damn happy customer and he's worth giving a call to and discuss your options.
Edit - you will definitly want to upgrade all 4 speakers - since the amp solutions he will provide will require better speakers to handle the increased watts being driven - Firecap will have all the details to walk you thru it.
Old May 15, 2009 | 10:48 AM
Chula's Avatar
Chula
Thanks All
Old May 15, 2009 | 11:35 AM
07hogman's Avatar
07hogman
Stage II
Default Stereo
I have an 07 Ultra Classic and bought a Four In Your Face System by Hawg Wired. I see no reason to get 6.5" speakers this system flat out rocks. They maybe a little spendier but I did find this site www.rocknhog.com that gave me a smokin deal on the system. I 've done alot of research and couldn't find a better deal. Another plus is that it was designed for Harley's and doesn't drain the charging system like regular car amps do. Hope this helps.
Old May 15, 2009 | 01:00 PM
lkr0's Avatar
lkr0
the digital amps do not strain the charging system, the Alpine PDX 4.150 is the way to go if you don't mind having a amp in the bag -- there will be a noticeable difference with 6.5 speakers
Old May 15, 2009 | 02:22 PM
langhammx's Avatar
langhammx
Default hawg-wired
I had the hawg-wired system and while it was quite a bit better that the stock, it's a far cry from the arc amp and 6-1/2" speakers. The 6-1/2" speakers make all the difference in the world.
The hawg-wired system is a real easy, plug and play system and install is painless. I changed my radio when I installed the arc system, and it's not quite a plug and play. Wayne is a real cool guy and is always willing to answer any questions. I used to install high end systems 20 years ago, and I still had to call him more than once, while putting it in my bike. All said and done, it really rocks.......
Old May 15, 2009 | 10:02 PM
HOGBOY57's Avatar
HOGBOY57
I also have hawg-wired 150 watt system and i love it had it in my 06 sg going to put it in my 09 sg. It sounds so clear you will love it. Talk to justin at hawg-wired hes the best.
cr2jones
Audio Systems
Jun 8, 2015 07:25 PM
Diggman
Audio Systems
Sep 27, 2013 10:44 AM
wilcoxracing
Apr 24, 2011 07:33 PM
mca1989
May 15, 2010 10:51 PM
woosh
Aug 5, 2009 07:25 AM
