how to remove O2 sensors. help
Old May 17, 2009 | 04:58 AM
Solitario's Avatar
Solitario
Default how to remove O2 sensors. help
hello, I've been told that, at least, in 2009 models, you need a special tool in order to remove the O2 sensors on the head pipe. The tool I've been told I need is HD-27714.
Is it true? can I use a regular tool in order to take the O2 sensors so I can change my headpipe at home?
Thank you for your help
Old May 17, 2009 | 05:25 AM
kingkingking's Avatar
kingkingking
You need to cut a slot in a deep socket and use a long extension. There is a pic in the workshop manual, i can scan it if you really need it.
Old May 17, 2009 | 05:36 AM
Ultra 08's Avatar
Ultra 08
First unplug the wiring connector, remove the header pipe, and use an open end or box end wrench after you get the pipe off. Worked for me.
Old May 17, 2009 | 05:37 AM
Solitario's Avatar
Solitario
please scan that pic. Thank you
Old May 17, 2009 | 05:42 AM
kingkingking
Of course. I feel a right ****. Just use a spanner once you have the headers off the bike...
Old May 17, 2009 | 05:56 AM
maineultraclassic's Avatar
maineultraclassic
What's wrong with a 7/8" open end wrench?
That's all I use when I remove / install o2 sensors. I do have a o2 sensor socket, but it's more of a PITA to use then the open end wrench.
Steve
Old May 17, 2009 | 06:07 AM
WingNut55's Avatar
WingNut55
Nothing.. a tiny little WD40 on the threads ( don't get any on the sensor tip )after you break it lose and a big 7/8" box end, work it out slowly reversing after each full turn so not to pull the threads out, works everyday for me ... The socket sucks and is a wast of time & money..
The socket is if your trying to change the 02 without pulling the head pipe off ...
Steve
Old May 17, 2009 | 06:26 AM
Solitario's Avatar
Solitario
I have never remove head pipes before. is it dificult? how long did it take you? any tips?
Thank you
Old May 17, 2009 | 06:29 AM
WingNut55's Avatar
WingNut55
Get a helper for a second pair of hands.. Take your time. I asume your Installing a aftermarket set of pipes ?
Old May 17, 2009 | 06:55 AM
Solitario's Avatar
Solitario
No, im just going to install the same Head pipe but without catalyst. It is cheaper than aftermarket headpipes and works fine
