Just got home from the Dyno.
Old May 17, 2009 | 03:57 PM
Landfill_Tim's Avatar
Landfill_Tim
Default Just got home from the Dyno.
I'm really happy with the build, I just wanted to show off a bit. I know it's not the the strongest thing around but it runs really nice.
Old May 17, 2009 | 05:07 PM
Suede Blue Man's Avatar
Suede Blue Man
Dude that looks great, you can't complain with those numbers! I think that head job really got those numbers cause I'm sure my 103" stage II numbers won't be as good as yours!
Making me want to yank my heads now! Thanks a lot
Good for you!
Old May 17, 2009 | 05:32 PM
reefrider's Avatar
reefrider
Great numbers........Fill us in on your build and head work more.
RR
Old May 17, 2009 | 05:38 PM
jag1886's Avatar
jag1886
That is good dyno chart, but you forgot to mention what the heck you did!!!
Old May 17, 2009 | 05:42 PM
armyof1's Avatar
armyof1
those are very nice numbers, i cant wait till i can attain them! good job.
Old May 17, 2009 | 05:57 PM
harleytuner's Avatar
harleytuner
looks like your tuner needs a little bit of schooling to me.
Old May 17, 2009 | 06:52 PM
EasternSP's Avatar
EasternSP
I'll be getting mine dyno tuned this Wednesday. Hope to get similar numbers.
Old May 17, 2009 | 06:57 PM
BadPiggy's Avatar
BadPiggy
Peak torque at 3600'ish RPM then drops off?
Numbers look good...think I'd want a flatter line on the torque curve, though.
Old May 17, 2009 | 07:03 PM
WingNut55's Avatar
WingNut55
He needs to spend a little more time tuneing , And at least have him run it in SAE.
Old May 17, 2009 | 10:06 PM
Landfill_Tim
It is a 95ci build with TRW forged flattops. The heads were decked and a cometic gasket was used to achieve 10.0:1 compression, it has a really nice port and polish job, but I'm still running stock valves and valve springs, the cam is a Bob Wood's TW-6 and is has a Stock Throttle Body bored out to a 51mm. SE Heavy breather and rinehart true duals. It also has compression releases that annoy the crap out of me. It's tuned Via PCIII. I think that is all. It was a low budget build, I got friends involved and put everything together myself, In total I've got about $3500 in it including the Exhaust (purchased used) A/C and PCIII.
As for the guys who questioned the tune, I understand the basics of tuning and by no means claim to really know how to pull it off, I was in the dyno room when it was run, this setup has been together for 4,000 miles now and I just swapped T/B. Prior to that I was making 97hp and 109ft-lbs. I'm friends with the tuner and would not call him out based on someone telling me there is an issue on the internet, however if you wouldn't mind explaining further as to what the issue is that you are seeing, I would tactfully approach him.
He has been a tuner for about 4 years now, He is not in a real performance heavy shop, most of what they do are simple a/c exhaust and cam jobs. So please give me a little more info as to what seems to be the issue. The a/f is nice and smooth on this, I saw it in person and I'm too ignorant to know how you can tell there is an issue otherwise.
Thanks, Tim
