Manual VS Adjustable Backrests
Old May 18, 2009 | 02:09 PM
PiedPiper's Avatar
PiedPiper
Default Manual VS Adjustable Backrests
Is the adjustable backrest worth the extra money? Going to Sturgis this year and want to put a back rest on my 02 RK but $300 for an adjustable is a lot of money. Seems to me, once you find the right spot for your back, you would just leave it there and not need to continually adjust it, which would negate the advantage of having an adjustable. Or am I wrong? Any comments from those of you with the manual backrests? Are you satisfied or do you wish you got an adjustable model?
Old May 18, 2009 | 02:20 PM
halfbreed's Avatar
halfbreed
I have the standard back rest on my 2001 Road King. I put an adjustable back rest on my 2007 Ultra Classic, and, as you have already said, once I had it adjusted, I never changed the setting. Personally, I will never but an adjustable back rest again. It's not worth the extra money, in my opinion. Halfbreed
Old May 18, 2009 | 02:58 PM
RThomas4223's Avatar
RThomas4223
Default Adjustable Backrest
I have an adjustable backrest on my 02 EGC. I find that on long rides, I do adjust it from time to time to change the angle of my back. It seems to allow me to ride longer.
Old May 18, 2009 | 03:14 PM
Zimbob's Avatar
Zimbob
I have the standard and have never felt the need to move it.
Old May 18, 2009 | 03:32 PM
Aleslinger's Avatar
Aleslinger
The adjustable backrest is easy to install, easy to adjust and hard to live without. I adjust it when I have more or less gear on, when I need more or less room for my passenger, when I want more or less distance from the bars for a different ride- lots of curves vs. long straight rides, when I have different boots -longer or shorter and when I want to shift around on a long ride. Also, I let a friend ride my bike and he was able to adjust the backrest in 3 seconds, he is now eternally grateful. It is good to have options and I never ride without it.
The standard has to be dialed in which could take some time, but is less expensive, I don't recommend the standard.
Old May 18, 2009 | 03:42 PM
RamDez's Avatar
RamDez
I run with the standard and it works great for me.
Old May 18, 2009 | 03:47 PM
Chicago Spike's Avatar
Chicago Spike
Yes, it is worth every cent!!
I had the adjustable on my old Road Glide, it was great, I would move it while I was riding. If I felt I wanted to relax a bit, I moved it back. When I needed to be alert, I raised it up.
I just traded the RG in for the new CVO Ultra. The CVO comes with a standard backrest. I rode it for 300 miles Saturday. It was the most uncomfortable 300 miles I've done in a while. I kept reaching to adjust it and I couldn't. I had to stop and do it and that was way annoying even to find the sweet spot. Even then I couldn't just flip it back with a finger. I went back to teh dealer this morning and my adjustable rest will be going on when I am back for my 1000 mile service.
So yeah, it is worth it
Old May 18, 2009 | 04:11 PM
honestbob's Avatar
honestbob
I've made up to 650 miles a day on mine with the standard one. No problems, very comfortable. I'm doing an Iron butt in June and find out then.
Old May 18, 2009 | 04:32 PM
jkoch09ultra's Avatar
jkoch09ultra
No problem with the manual BR. I have had 2 and I like them. I never move it after it is set. If my butt gets sore I just move foward and lay back and put my feet on the highway pegs. I alternate positions and do very well on long trips. I put it on myself and saved the cost of the labor. I never ride without it.
Old May 18, 2009 | 04:41 PM
oldbagr's Avatar
oldbagr
I had the manual backrest installed at time of delivery. Once I got it set I have never changed it and I always ride with it on the scoot.
