Break In Method
Old May 20, 2009 | 01:49 PM
beary's Avatar
beary
I've been all around this and I think riding somewhat normal is will work fine.
I personally like the Mototune method but I can understand the fear from folks who don’t understand engines and mechanics. My dealer's advice when I walked out the door is about the same as the directions in the owners manual. I did question him about the speed limitation for the first 50 miles because that didn't make sense to me. He thinks it keeps the rider at a safer speed incase something fails on the bike (belt sprocket?) because of incorrect assembly. OK, I’ll buy that.
The manual and dealerships also say not to ride at the same speed for the first 500 miles. I take that to really mean don't ride at the same RPM, but nobody I asked seemed to have a good explanation for that procedure. My guess, based on many years of breaking in engines including aircraft engines, is that procedure insures an even break in of the whole cylinder. Higher RPMs stretch out the piston and crank, so varying the speed makes sure the engine is run at higher RPMs (higher meaning between 3300 RPMs and 4000 RPMs).
So, I think you can achieve a good break-in with normal riding making sure you stretch up to 3500 RPMs now and then for the first 250 miles and 4000 and 4500 RPMs up to 500 miles. It’s really not hard to reach those RPMs when accelerating up to normal cruising speeds, most of us do it in normal riding anyways. Most riders will have a harder time holding the revs below 3500 for the first 250 miles because that is not as high as most think.
That is my 2 cents.
Beary
Old May 20, 2009 | 01:53 PM
Bossman1's Avatar
Bossman1
My theory with no problems has always been easy for fifty and then break it in like ya want it to run..............
Old May 20, 2009 | 07:32 PM
springerchop's Avatar
springerchop
ride it like you stole it. Break ins are for the timid.
Old Jul 18, 2009 | 10:56 PM
lclement's Avatar
lclement
I have 225 on mine think I may do the 30-60 mph roll on’s to seat the piston rings so I don’t get as much blow by. I have been ridding on the interstate after 87 miles but I very the rpms at least a few hundred. The motor should be good from 0-3500 rpms but think I need to stretch to 4500 to reach that range.
Old Jul 19, 2009 | 12:11 AM
PhilM's Avatar
PhilM
I've been using the method from that link for years ~ both on new bikes and performance builds.
It works. I have not had a single problem as a result of it.
Some may say they have never had a problem with mellow break-in too. What they don't know is that their motor is also more mellow than one that was done quick, right from the get-go.
When I do a build, I use a MAP "close" to the build and as soon as the lifters pump up and quiet down I go out and do the "ring seating runs". The next miles come on the way to the dyno shop where the motor gets a FULL TUNE ~ none of this 40~50% crap that you sometimes hear about.
After that, the original oil gets changed and then again about 500 miles and then at approx 2500, they get your favorite synthetic (AMSoil, Redline, etc.)
Old Jul 19, 2009 | 08:13 AM
Chicago Spike's Avatar
Chicago Spike
Agree with Phil here,
Break in an engine with the slow method, you get a slow engine
Break in an engine with the quick methoid, you get a quick engine
Old Jul 19, 2009 | 08:39 AM
greginNH's Avatar
greginNH
Another thing to remembersis to avoid full throttle accelerations during the break in period. Taking the motor gradually up what ever RPM you want is fine. Probably with worst thing you could do is take a new bike home on the highway and set cruise contriol to 65 MPH for a 100 miles stretch.
I usually choose the backroads with hills to break in my bikes. Different topography adds to the vaiations of conditions in break-in. I just hit 250 miles yesterday with my EGC and it was the first time I actually took it on the highway (sixth gear is great).
I haven't taken it past 3,500 RPMs yet but will be doning so on short bursts today.
Old Jul 19, 2009 | 08:46 AM
rg_dave's Avatar
rg_dave
Plus 1,000,000
I have used this method on every bike I have owned race or street. Works well.
Old Jul 19, 2009 | 11:45 AM
iclick's Avatar
iclick
I would advise doing some research before applying the Motortuneusa recommendations. In 50 years of fooling with cars and MC's I've never seen one vehicle manufacturer that recommends a procedure as described there, or any other hard-break-in technique. I would go by the book and concentrate on varying the speeds continually. No need to baby it, but don't lug it or rev it beyond the recommendations.
Old Jul 19, 2009 | 01:13 PM
Chicago Spike
Most high end vehicles like Mercedes, BMW, Porsche all have you break in the engine HARD. As others have said, they've broken in many a HD engine HARD and they work better than the engines that are broken in by the rediculous HD way of staying below 50mph for the first 1000 miles, then below 60 for the next 4000. I laughed at my salesman when he said this to me.
But, as with oil debates, it's your engine your bike, do with it how you will.
