Break In Method
Old Jul 19, 2009 | 01:50 PM
drewski1325's Avatar
drewski1325
It's all about heat. A fresh engine generates more heat till broke in and needs more lubrication. The piston rings literally scrape against the rough cross hatch hone pattern in the cylinder bore. The cross hatch acts as little troughs to carry extra oil down the cylinders for extra lubrication. As engine RPM rises so does the heat as there is more friction. Excessive RPM will increase the heat further where the oil literally burns and dries the oil film faster than the oiling system can replenish it. Scuffing then occurs between the piston and the cylinder walls. Unchecked the piston skirt will expand causing more friction and eventually the piston will grow too large for the bore. The galled piston will seize in the bore. That is why the MOCO recommends an easy break in and not to exceed certain RPM's and speeds for certain mileages. They have to warranty your motor.
S&S and other performance engine builders have "loose fit" specifications where an engine can be ran up to higher RPMs sooner and not have the excessive heat issues.
You can do what you want but after spending $20,000 + on a motorcycle I think I'll do as the factory suggests. They got smart guys that work there with letters after their names like PHD.
Old Jul 19, 2009 | 02:05 PM
tibadoe's Avatar
tibadoe
I just followed the manual and used some common sense. No lugging at any time and varying the speed/rpms. Never had any problems with any bike I had.
Old Jul 19, 2009 | 02:13 PM
CW4_131A's Avatar
CW4_131A
Ride it like you'll ride her forever.
A gently broken in engine won't know how to act when you give her the goose.
Old Jul 19, 2009 | 02:15 PM
CW4_131A's Avatar
CW4_131A
Oh, and lube her earlier then the manual states.
Drewski has a point about the engine and specs.
Old Jul 19, 2009 | 02:58 PM
rodeking's Avatar
rodeking
I break mine in on the Interstate. Up through the gears, WOT, cool down for a few miles and do it again. About five times and 25 miles should do fine. We break in air cooled lyc and Cont at WOT throttle untill the oil temps start to drop. Works better than the low and slow method. The cross hatch in the cylinders is to seat the rings before the cylinders glaze over. WOT puts more pressure on the compression rings and seats them before the hatch marks are gone and the cylinders glaze over.
Old Jul 19, 2009 | 03:02 PM
n8dc's Avatar
n8dc
he has to have it broke in by now ...
SSTuner
Mar 26, 2012 05:53 PM
tx-skydiver
Aug 15, 2010 03:01 PM
jackinthebox
Jul 2, 2009 10:57 AM
hrchdog
Aug 17, 2008 09:28 PM
pwnzilla
Oct 4, 2007 03:51 PM
