Speedo problem..
Old May 20, 2009 | 10:30 PM
Povertynob's Avatar
Povertynob
Had the same thing happen, blown fuse caused by dead short behind the head light. The wiring bundle was catching on the steering head zerk and had worn thru the insulation. Took me a while to trace that little bit*h out. Ended up replacing the zerk with a plug, just reinstall a zerk to grease then put the plug back in.
Old May 20, 2009 | 10:56 PM
Paniolo's Avatar
Paniolo
If it's a '94 it has a speedometer cable hooked up to the front wheel. It's either the cable, or the gear in the hub.
Mark
shake rattle n roll
Mar 28, 2010 01:36 AM
loneshark666
Mar 26, 2010 01:48 PM
kanderson586
Electrical/Lighting/Alarm
Aug 13, 2008 09:11 PM
laz
May 24, 2008 12:13 AM
biker Mike
Jun 24, 2006 01:21 AM
