Primary Oil
Old May 20, 2009 | 12:37 PM
Globeracer's Avatar
Globeracer
Default Primary Oil
This may be a silly question, but here it goes. If I am only going to change the oil in the primary and not adjust the clutch, is there any reason to remove the derby cover and change that gasket?
Old May 20, 2009 | 12:44 PM
petemac's Avatar
petemac
You don't say what year your bike is. Does it have an inspection cover for the primary? My '06 does and this is where I put the primary oil in.
Old May 20, 2009 | 12:51 PM
honestbob's Avatar
honestbob
I guess you could put the oil in like you do on the foot of an outboard. Never tried that but think I will next time I change it.
Old May 20, 2009 | 01:37 PM
huffhuff's Avatar
huffhuff
shouldn't have to change the o ring on the derby cover. i changed mine several times on my 01 with no problem with no replacement.
Old May 20, 2009 | 03:01 PM
Globeracer's Avatar
Globeracer
Default Primary oil
It is an 06 roadking. It does have a inspection cover.
Old May 20, 2009 | 03:04 PM
petemac's Avatar
petemac
Just dump the oil in through the inspection cover. You won't need to replace the gasket unless it's damaged. Still using my original one and still in good shape.
Old May 20, 2009 | 03:09 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Pouring oil through the derby hole is a bitch. Never do that. Always through the inspection cover if you have one. FYI, my gasket is not a o-ring but rather some kind of plastic disk thingie.
Curt1953
Aug 16, 2015 03:11 PM
BigDawgQC
Dec 5, 2012 07:56 PM
ruin66
Apr 13, 2011 07:22 PM
BEN-Z
Jun 18, 2010 04:59 PM
Thomto
Aug 13, 2009 09:43 PM
