Mine sounds like quick repeating chirps, not a long drawn out anything.
Originally Posted by Chicago Spike
Because a "Chirp" is a short quick sound. While a "whine" is a long drawn out high pitched note
Chirp = eep
Whine = eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeee
I like having the different sound in 5th gear. It helps as an indicator for what gear I'm in. I don't see it as a whine; it's just a different sound. It is not a problem; the gears work just fine.
I agree, it's nice to hear the difference at times.
"I don't even notice the whine anymore, frankly, or at least rarely and don't consider it a problem. It certainly isn't a "mechanical problem" since it is caused by the spur-cut gears and is a normal side-effect of the stronger gear set for 1st and 5th gears."
Ditto.
I don't really notice it that much nor does it bother me. Now as to the OP's original question: No the whine seems the same on my '09 RK (not worse or better). I'll be turning 12,000 miles today on my way to work. For those who haven't noticed 1st gear has this whine too. I use Amsoil 75W-90 but will be trying 75W-140 at next oil change just out of curiousity.
I've never noticed and if I did notice I wouldn't care about it. The source of any 'whine' is known - straight cut gears and it's NOT a problem. Why does this keep coming up?
This question comes up often with newer riders. In 2007 the MOCO introduced a new six speed transmission. It was designed by engineers who made the first gear and the fifth gear straight cut gears. The theory behind this is that straight cut gears offer more strength although the downside is that they are not as quiet as their hellicul cut cousins. Further, the design engineers theorized that since so much time was going to be spent in first and fifth gears that it just made alot of sense to use straight cut gears. My own theory would be that straight cut gears are not needed and the engineers had it wrong. But, that has been debated far and wide and they haven't changed yet.
So, what can you do to lessen the noise if it bugs you to death? Probably the most effective thing to do would be to run a true gear oil in the transmission instead of dino oils or synthetic motor oils. I run 75/140 weight in mine in the summer and 75/90 in the colder months. After awhile it just becomes a non issue.
The 5th gear chirp doesn't bother me, but I find what you just wrote interesting. We keep reading so much on the benefits of synthetic oil, so I would like to learn more. What is a true gear oil compared to tanny oils we read about here? Is the Harley Formula+ a true gear oil?
