Loose Baffle?
Old May 24, 2009 | 08:32 PM
atrain68's Avatar
atrain68
Default Loose Baffle?
I am having trouble with this one. Since I put on my new slip-ons I've had this loud metallic knocking sound coming from around the right muffler at idle and low RPM's. If I put some pressure on the muffler the rattle stops. I am sure the sound is not coming from the luggage rail and the rubber mount is brand new - I replaced it just to see if that was the problem.
Can baffles be the source of this kind of sound? If a baffle is loose does anyone know if that might contribute to decel pop? I've checked for leaks and there are none. Thanks!
Old May 24, 2009 | 08:54 PM
Bertk's Avatar
Bertk
Yes, baffles can come loose and make a sound you describe. You didn't mention what slip-on you installed? And considering there new, you will want to check with the manufacturer also. I would take care of the baffle problem before tackling the decel popping problem.
Losthwy99
Jul 5, 2011 01:25 PM
ironfist_001
Exhaust System Topics
Aug 16, 2009 11:56 AM
mrsnipy
Mar 12, 2007 08:05 PM
MDMYMD
Sep 30, 2006 07:56 PM
yodal
Jun 4, 2006 03:14 AM
