Any better ideas?
Old May 27, 2009 | 11:26 AM
BiggestDawg's Avatar
BiggestDawg
Advanced HDF Member
What I was asking is how does the jug come off with out having to remove the cylinder head and all associated hardware? I have not looked closely at this yet but I will be so I will figure it out. I have the manual and WILL READ it.
Originally Posted by Jinks
Huh?................
Old May 27, 2009 | 12:04 PM
Jinks's Avatar
Jinks
Your original post implied a reasonable level of mechanical experience. With that in mind I was a little surprised at your question since I'm not familiar with a reciprocating engine that doesn't have the cylinder head on top of the jug/barrel/cylinder, & needs to be removed to access any base gaskets (assuming that the cylinders are removable).
You will need to remove the gas tank, the carb & manifold, head, & maybe drop the motor lower in the frame by removing the front motor mount. None of which is very complicated or time consuming. I'm guessin' that since you feel confident in working on your transmission, you shouldn't have any problem with base gaskets. You'll need more specialized tools for the transmission than for the base gaskets. The only specialty tool you'll need there is a ring compressor.
Old May 27, 2009 | 12:31 PM
BiggestDawg
Advanced HDF Member
Ok that was what I was assuming. It just looked like from the one statement that there was a way that I was not seeing and just wanted to clarify that. Since I already have the exhaust manifolds off it will not be hard to do the rest and get at it. Since I am already this far into the job I will probably go after that as well I don't see any reason to tear it apart twice to do what I should have done when I was that close in the first place.
Old May 27, 2009 | 12:54 PM
JonnyD's Avatar
JonnyD
Hey Virg, gimme a call when you start the tear down, and I'll come give you a hand. I wanna check out the innerds of the EVO anyways. I'll bring the beer
Old May 27, 2009 | 01:36 PM
BiggestDawg
Advanced HDF Member
I'd be happy to. PM me you number. I have not been going at high speed on this due to a project I am working on for my parents 50th wedding annivesary but with the weather staying nicer longer the itch is getting really bad. BTW I brew my own beer so you'll need to bring the good stuff
bparsel
EVO
27
May 6, 2021 06:01 AM
Hury
Product Reviews
Aug 15, 2011 08:11 AM
ChopinRockwooD
May 8, 2009 03:22 PM
hotrod351
Exhaust System Topics
Jun 25, 2006 06:14 PM
