Installing oil temp gauge in FLHTC
Old Jun 2, 2009 | 05:18 PM
  #31
FX4 Level II's Avatar
FX4 Level II
I have the McEwan gauge also, I routed mine to the right frame rail on the inside, up towards the battery box and up under the tank and into the inner fairing, fairly simple install. Also, the McEwan you do not need any adapter or anything, looks nice.
Old Jun 2, 2009 | 05:31 PM
  #32
sifularson's Avatar
sifularson
The HD gauge goes to 350, I believe the McEwan goes to 300. Am I correct?
WIthout an oil cooler on my bike I pegged that gauge at 300 a couple times in traffic. That's when I installed an oil cooler and a HD gauge.
Just my 2 cents.
Steve
Old Jun 2, 2009 | 05:40 PM
  #33
soos's Avatar
soos
Originally Posted by sifularson
WIthout an oil cooler on my bike I pegged that gauge at 300 a couple times in traffic. Steve
Dayum, haven't you learned by now that you are supposed to avoid all traffic and especially sitting in it? Geez...
Old Jun 2, 2009 | 06:20 PM
  #34
Dalton's Avatar
Dalton
If my gauge ever hit 300 degrees, I think I would have a stroke! Highest I have ever seen is 260 sitting in traffic and I was upset then!
Old Jun 3, 2009 | 07:21 PM
  #35
led's Avatar
led
2nd Gear
To make sure, the next time you change oil pull the plug out that you were going to put the sending unit in and see how much oil comes out. Then decide if you want to change the location
Old Jun 3, 2009 | 08:14 PM
  #36
Bad Pig's Avatar
Bad Pig
Originally Posted by tslonige
The Rodger McEwan oil temp guage fits the batwing and the color matches the other guages. I put the one FLTSE 2002 - Present in my 06 StreetGlide and it comes with all the wires and fittings. Works great in place of the air guage.
where did you get the gauge? do you have a part#?
Old Jun 3, 2009 | 08:51 PM
  #37
acchd's Avatar
acchd
Badpig I found kits here for $85.
http://www.phatperformanceparts.com/...ctCode=GK61537
Old Jun 9, 2009 | 05:25 PM
  #38
dugatada's Avatar
dugatada
3rd Gear
All kits appear to for 99 and newer. looking at the oil pan on my 98 flhtc, it appears to not have the extra hole for the sender. is this the reason for no kits for 98 and older? would like to make this mod. any suggestions?
Old Jun 10, 2009 | 08:09 AM
  #39
FX4 Level II
Your right the McEwan gauge only goes up to 300 degrees, but I have an oil cooler already so I shouldn't come anywhere near that temp! And if I do, I guess it's time to pull over and let 'er cool down! I read dino oil breaks down at 250 degrees and synthetic at 300? I run synthetic.
Old Jun 10, 2009 | 09:25 AM
  #40
HarleyWood's Avatar
HarleyWood
Originally Posted by UALCapt
Just installed one myself. Question though ... I was going to use the (inner) oil pan plug as illustrated in the photos above, but my dealer service manager said not to because that plug leads to an oil pan chamber that "has no oil in it". So I used an adapter to fit the probe into the oil drain plug (outer) hole. Obviously, when I drain oil, I have to remove the probe to do it. I have a feeling I got some bad info! I assume the inner plug works fine for all of you? Thanks.
well..I can say for a fact that when I pulled the plug, oil drained out
