TBW Connection
Old Jun 1, 2009 | 07:49 AM
Trippie's Avatar
Trippie
Default TBW Connection
Ok, I have the "accessory" TBW harness (has no green connector).
Now, instead of the nice colors I can follow in my Service manual for the hook up, I have 2-reds, 2-blacks, 2-white wires.. Does anyone know the sequence for hooking these up? I know it's a reduntant set up, but just need to know the sequence...
thanks!
Old Jun 1, 2009 | 08:39 AM
realmccoy01's Avatar
realmccoy01
It's been a while since I did this but assuming that you have the old twist grip sensor, lay them side by side, make sure that they are indexed appropriately (line up the notches on the sensors) and mark the new wires with the same colors as your old wires. Then everything will match the diagram. If you don't have the old one, it's going to be a bit more complicated.
Old Jun 1, 2009 | 08:41 AM
Trippie's Avatar
Trippie
Yeah, i got nothing as far as old harness or anything... got the bike back from the dealer (who could not run the harness through the bars, took me 23 minutes to do it....Another story)
i'm flying blind so to say..
i'm headed there after lunch to see what those hacks say.
Old Jan 8, 2010 | 12:20 AM
Fourseventeen's Avatar
Fourseventeen
Stage II
you ever figure out the wire color/locations? I am having this same issue and need to get it figured out asap so I can ride
Old Jan 8, 2010 | 12:52 AM
Sancho's Avatar
Sancho
The dealer could not run the harness through the bars? Sounds like the dealer just didn't want to do it. Removing from the old bars and running through the new ones might have taken me 5 minutes. Sweepers +2.
Old Jan 8, 2010 | 12:55 AM
dawg's Avatar
dawg
Read THIS thread and it should help you.
Old Jan 8, 2010 | 05:31 AM
IndyClassic's Avatar
IndyClassic
Had same problem a year ago and you guys were great! I thought by now HD might have put a small slip of paper in the box with the match-up. Wishful thinking I guess.
gilbyfltr
May 12, 2020 06:18 PM
Strait
Oct 6, 2012 08:26 AM
Mark98012
May 1, 2012 01:56 PM
Doc Danielz
Apr 9, 2011 09:47 PM
BlackFLHR
May 19, 2009 03:10 PM
