ape question
Old Jun 2, 2009 | 12:48 PM
max56's Avatar
max56
Veteran: Coast Guard
Originally Posted by captaincaveman
Point well taken, but that wasn't the question
Josh
Okay, let me address your question more specifically. I used +6 for my 16" bars. If you put 18" bars on using +8 you can always switch to 16" bars and just tuck the extra wire away. However, my original point still trumps all of what I've written here. It's a lot of work. As I mentioned, I went with 16" but I don't think 18" would have been bad at all. Just not worth all it would take to try it. Good luck whichever way you go.
edit: after some more thought...if you started with 18" and went to 16" your clutch cable and upper brake line (if you're running dual disks) MAY be longer than what you'd want. The internal wiring on the bars would be a non-issue.
KIDD_ADMC
Feb 15, 2014 11:53 AM
hbarleatherneck
Jan 11, 2010 08:11 AM
DStonestreet
Sep 10, 2009 09:52 PM
dslwraith
Sep 18, 2008 07:07 AM
wideglidebob
Jun 30, 2007 12:24 PM
