super tuner or power comander V
We can do the same by adjsuting our Closed Loop Bias, just not recommended to go below 14.2 as the sensors won't last as long and the data gets sketchy with the narrowband used for close loop operation. If I want richer I need to go out of Closed loop. At that point I loose much of the ECM's 'autotune' features and rely on the Volumetic Efficiency tuning I performed to ensure that the correct AFR is applied.
Also, please explain "V-Tune," as I'm not familiar with it.
<snip>
I disagree again, if you have a build that's no where close to the base calibrations you have a good case for a dyno, but again if I'm building that bike I still buy the TTS and just have it dyno tuned.
Fuel Moto sells them all, except SEST, and uses the PCV for all their Power Packages. He's not making a big profit on these so I don't think profit is his primary motive for selecting them as the tuner of choice. I guess it's a matter of preference and it's good that there is so much to choose from. That's good for the consumer.
http://www.mastertune.net/files/Tuni...ning_Guide.pdf
By changing the voltage we are able to get the O2 sensors in different areas
V-tune is the name of the program to tune the bike. This process changes your ve charts and tunes the bike. The base map is only a starting point. It would be nice to have one close so your not tuning for more then 3-4 runs. but not really needed 2-1 exhaust vs jackpot vs. true-duels would all use same base map(calibration file)
List of calibration files
http://www.mastertune.net/files/Tuni...ileListing.pdf
Is there a good "primer" somewhere on the web, to learn the basics of these tuners, including terminology like "AFR", "AT modules", "zeroed map", "WOT", "VM tables", "TP/RPM", etc?
Why is the Screamin' EagleŽ Pro Super Tuner Kit not shown anywhere on the H-D website? I've searched everywhere, including by part number (32109-08) and it's not there. With the 103 and 110 upgrade kits, I'm surprised there's no mention of the SEST anywhere on Harley's site.
Thanks for any help!
Screamin eagle parts here..
http://www.harley-davidson.com/wcm/C...p?locale=en_US
[/Quote]
V-Tune is the software used to calibrate your Volumetic Efficency for both front and rear cylinders. Once I get the VE's right the AFR's fall into place as when the ECM asks for a specific AFR it knows that based on the VE's it needs to allow this much fuel to ensure that the AFR is what is measure on the other end. This isn't required at all AFR's using a single AFR allows you to calibrate for all AFR's (this allows use to tune VE's at WOT cause we use an AFR the sensors can read during this portion of the tune)
I tune my VE's for my map in Closed Loop, so that when I open up areas of my map for Open Loop the AFR I specify will be the AFR I recieve. MAP and RPM tell me where I am on the 'grid' and what AFR to deliver in both open and closed loop. Our VE's get calibrated by running a few short 30 minute rides and taking the data the ECM thinks it giving in terms of AFR compared to what is measured at the O2 sensors, then adjusts. So if it was 90% it now might be 87%. This is all measured, no buttometer. The desired AFR doens't need to be constantly adjusted as the ECM does this already in closed loop and with my VE;s calibrated in the open loop portion the ECM knows how much fuel to deliver to obtain my target AFR for that area of my map.
Right for pipes/AC combos we have a few different maps but they are really just the same and any differences are going to be customized during our tuning session (V-Tune). For my 2-1 I just took an extra run to calibrate.
For other upgrades there are other maps calibration files, I haven't looked to deep but I don't see specific CAM names other than SE. While I am not yet certian I would beleive that SE255 has some kind of Woods counterpart. Since I don't know specifically on the details for this type of set up this is where I wish that TTS had more calibration files OR stated that they where good for Woods 'X' CAM and SE255 ect.
In some cases I mean a map like a base map and in some cases i mean MAP as in Manifold Absolute Pressure. I think I capitalize the latter.
Great discussion and a welcome distraction from an other wise boring workday...
AFR - Air Fuel Ratio
AT Module - Auto Tune Module (PCV)
WOT - Wide Open Throttle
TP - Throttle Position
RPM - Revolutions Per Minute
VE - Volumetic Efficiency (sp)
SP - Spelling
CLB - Closed Loop Bias
