Syn3 or Amsoil
Old Jun 9, 2009 | 09:48 AM
Jim Dawson's Avatar
Jim Dawson
I've been using Amsoil in all three holes until I put Redline Heavy in the transmission the last time. That is some evil looking crap and I saw no difference is shifting or tranny noise so I'm not using it the next time.
I had compression releases installed last month and the mechanic called me to show me how much carbon was on the heads and pistons. We were both surprised at how much there was after only 16,000 miles. He asked me what kind of oil I used and I told him Amsoil. He indicated that he sees that often with Amsoil. I think I'm switching to Mobil 1.
Old Jun 9, 2009 | 12:55 PM
boogiewithtuck's Avatar
boogiewithtuck
Originally Posted by electricstart
I did amsoil 20 -50 M/C in motor,redline in tranny, drag specialties primary oil in primary. This from my local bike shop recomendation .Bike shop recomended mobil one vtwin for motor.I wanted Amsoil. These guys been building and services H/D s for many years.Harley recomends Syn 3 in all compartments, Amsoil recomends 20-50M/c in all compartments. The choice is up to you. Probably cant go wrong any way you go. All very good oils.
Mob1 V-Twin oil in the engine (where oil belongs), Mob1 syn. ATF in the primary, Mob1 syn. gear oil in the trans - easy to find, somewhat affordable...
Old Jun 9, 2009 | 12:57 PM
boogiewithtuck
Jim,
Can you expand on the compression release install? I ride old dirt bikes so I know what your talkin' 'bout, just curious about the application.
Old Jun 9, 2009 | 01:28 PM
emwolb's Avatar
emwolb
the problem i have with amzoil is that there are like eleven dealers on the planet. thanks anyway, i want to use an oil that i can find anywhere. royal purple 20-50 is what i'm running in the crankcase and primary, and the royal purple 75-140 in the trans. a perfect combo, although royal purple almost doubled in price in my area lately, so i got five quarts of syn 3 for my next change. the royal purple i can get at o'reileys, pep boys, auto zone, all of the major chains. but with syn 3 at 9 bux a quart vs 17 a quart for royal purple. and a huge difference it made. runs noticeably cooler, and the trans almost shifts as well as a jap bike. very quiet and smooth, a click rather than a clunk
Old Jun 9, 2009 | 03:01 PM
Wassup8687's Avatar
Wassup8687
I'd do Amsoil or Mobil 1 in all 3 holes.
Old Jun 9, 2009 | 03:20 PM
davewear's Avatar
davewear
amsoil 20w50 in all three holes. nice to be able to carry 1 bottle to top up engine or tranny if needed on a trip
Old Jun 9, 2009 | 03:22 PM
beary's Avatar
beary
I quit using synthetic in the primary, it made the clutch harder to use in the friction zone. It seem to bite to hard. A 10w40 oil works pretty good, but I've wondered how a gear oil would work.
Beary
Old Jun 9, 2009 | 03:38 PM
Jrsess's Avatar
Jrsess
Amsoil 20/50 all three holes.
Old Jun 9, 2009 | 04:21 PM
BGHFD's Avatar
BGHFD
Originally Posted by keltonkrew
Mobil V-twin 20-50 in the crank. Mobil 1 75-140 in the tranny and syn 3 in the primary (just cause I have about 6 qts of it left and needed to use it). when gone, will be mobil 1 20-50 in primary as well.
I've heard that even Harley is saying not to use Syn-3 in the primary. I used to run Syn-3 in all three holes, but started to get clutch slippage and wear. I heard that Syn-3 is too slippery for the clutch and the primary doesn't require such sophisticated oil. I was going to switch to the HD Formula+ and got talked into the RedLine regime by the HD dealer.
Clutch action is MUCH better with RedLine MTL (now RedLine Primary oil) in the primary. Not much difference with the Shockproof in the trans and the engine ran fine with Syn-3 and RedLine. Considering going to Mobil-1 for reputation and cost.
2003 Heritage
Old Jun 9, 2009 | 04:44 PM
garyhendley's Avatar
garyhendley
i run 20/50w in the motor and primary and 75/90w sevear gear in the tranny
bike is smooth-ride safe
