Sert super tuner problem?
Old Jun 9, 2009 | 07:28 AM
SlowGlide2989's Avatar
SlowGlide2989
Default Sert super tuner problem?
Hows it goin everyone? Purchased a super tuner the other day and for now until I have time to get this thing on a dyno I was gonna use a base map off the program. But when I select a map and open it up, when the fuel chart comes up to view, there are no changes on the chart. Everything remains 0.0 across the board. My friend has a v-rod with a sert and he says it shows all the changes through the fuel curve on his. If anyone could shine some light on this, its greatly aprreciated. Thank you. Also even though it shows no changed there is still a map there because i downloaded it to the bike and it seemed to make a big difference. Just a lil worried dont want to start riding this thing uptill its resolved. Thanks again
Old Jun 9, 2009 | 02:28 PM
SlowGlide2989
bump
Old Jun 9, 2009 | 04:45 PM
johnltex's Avatar
johnltex
You may be in the "basic" tuning mode. Look for a option to change to "advanced" tuning. I'm not in front of my PC right now but when I get home I'll take a look and see exactly where if you don't find it by then.
Old Jun 11, 2009 | 07:42 AM
SlowGlide2989
well went into the setup and switched it to advanced tuning and now it shows the table with the a/f set at like 14.6. and it will only let you change figures at 20% throttle and everything else is locked... Can you not make changes to a base map?
Old Jun 11, 2009 | 02:14 PM
SlowGlide2989
Well i guess i wont ask anymore question untill i play with ths a lil more. For anyone debating between a powercommander and a sert all i can say is "say what you want about power commanders untill you play with a sert way more stuff to mess with." but thanx john for pushing me in the right direction figures werent locked they were maxed out at 14.6 up to like 4000 rpm and 70-80 percent throttle.
rahall
Nov 14, 2008 07:48 PM
ericsenf
May 4, 2008 11:31 PM
300potato
Mar 21, 2008 03:22 PM
jasonfish
Nov 20, 2007 10:57 AM
Phast Lap
Oct 11, 2006 12:45 AM
