battery charge
Old Jun 11, 2009 | 02:37 PM
tooskie's Avatar
tooskie
Stage II
Default battery charge
I ride a 1991 Ultra. I had the stater replaced last fall. Last weekend I noticed while riding with my headlight on the battery discharges so low my directionals don't work. If I ride without the lights on the battery maintains a full charge. Any guesses?
Old Jun 11, 2009 | 02:52 PM
jamesw's Avatar
jamesw
Short?
Old Jun 11, 2009 | 02:56 PM
papa_freeman's Avatar
papa_freeman
Originally Posted by jamesw
Short?
+1
that's where i would start
Old Jun 11, 2009 | 03:15 PM
tooskie's Avatar
tooskie
Stage II
That's where I'll start. Thanks for the replies.
Old Jun 11, 2009 | 03:40 PM
n8dc's Avatar
n8dc
Ok if it was a short not only would the amp gauge be to the minus side of zero it would prolly blow a fuse.. Is suspect a bad or weak charging system component before id call short.
Old Jun 11, 2009 | 03:58 PM
frog13's Avatar
frog13
+1 A battery on a full charge will last a while without lights. Turn on the lights, it's going fast. Pull the seat, run the bike and put a voltmeter across the battery. You can look in the manual for the exact numbers but you need to be getting 12+ volts at the battery, usually more in the 13-14 range. You can usually tell right away if you give it a little throttle, there will be a small increase in voltage. If not, time to figure out if it's regulator, stator or rotor. If the charging system is ok, which I doubt based on your symptoms, all that is left is battery and wiring. The battery can be load tested at any battery center or your local, friendly HD dealer.
TexSport2013
Jan 23, 2014 04:47 AM
P Diddy
Aug 30, 2012 09:21 PM
CWDoc115
Aug 21, 2011 09:59 PM
Rynb15
15
Aug 16, 2008 06:18 AM
murph
Dec 12, 2007 10:02 AM
