speedo problems
Old Jun 14, 2009 | 06:45 AM
fastalkintn's Avatar
fastalkintn
Default speedo problems
Went for a short ride yesterday and on the way home noticed my speedo is not working and my blinker reset is not working. The blinkers work but do not reset after the turn. The odometer is showing the miles but does not change. Any ideas of things to look for? thanks for the help.
Old Jun 14, 2009 | 06:52 AM
Road Ranger's Avatar
Road Ranger
Did you check for any blown fuses?
Old Jun 14, 2009 | 07:00 AM
Papamte's Avatar
Papamte
The speed sensor is bad. You can pull it and clean off any metal you find, and it may start working again. But, if it doesn't then you'll have to replace the sensor. It's on top of the transmission behind the oil filler and under the starter solenoid. It plugs in under the seat in front of the battery.
Old Jun 14, 2009 | 09:06 AM
fastalkintn
All the fuses looked ok, I'll try to clean the sensor tomorrow. Thanks for the help.
Old Jun 14, 2009 | 09:31 AM
kyote's Avatar
kyote
Default Just happened on mine....
You may still have a mechanical Speedo drive. Dealer told me that only recently the speedo's were no-mechanical. Check the drive on your front wheel. Mine needed to be replaced.. same symtoms as yours, AVC didnt work, turn signals didnt cancel & no speedo.
was approximately $45 for the speedo gear.. only took about 20 mins to replace.. front wheel removal is required.
Old Jun 14, 2009 | 04:34 PM
Papamte's Avatar
Papamte
2000 models have the speed sensor!
Old Feb 27, 2010 | 06:30 PM
scmetalhead's Avatar
scmetalhead
Stage III
I have had the same problem on my 99 EG Classic. Turns out it was the last year for stock mechanical speedo, wich i also found out that the drive is hard as hell to find. Yes, your speedo is electric. And at the time i am writing this, you've prob long since fixed the problem.
Straight_To_Hell
Electrical/Lighting/Alarm
Jun 15, 2014 01:49 PM
venomv8
Jun 15, 2014 07:10 AM
PanHeadRich
EVO
Aug 28, 2012 06:38 PM
C-rain
Jul 22, 2009 12:39 AM
eshayne
General Topics/Tech Tips
May 5, 2009 07:47 PM
