Mid-frame air deflectors - install PITA!
Old Jun 21, 2009 | 05:26 PM
iclick's Avatar
iclick
Originally Posted by matrix5
That's the freaking truth.... Pulled one of the bolts out and "bonggggg" The stupid fender and whatever else is supposed to line up didn't anymore. I've done things where a 3rd hand would be helpful, but I'd bet an octopus would have a hard time with those effers.
Yep, got a "bongggg" here too, and getting those pieces lined up again while trying to insert the bolt and holding the cage nuts in place was almost impossible for one person. What's more, the cage nuts that were supposed to stay put but didn't, falling in the fender/frame brace several times and only retrievable with a magnet. The instructions were almost comical: "Remove bolt, insert cage nut, and tighten bolt. Yeah, that's like building the shuttle with instructions like "Assemble parts, fly shuttle." It was unbelievable and at one point in time I thought the job might never get completed.
New-bike owners don't know what they're missing, as for '09's it's apparently a 30-min. job like my old Evo RK was.
Old Jun 21, 2009 | 05:36 PM
Jim Dawson's Avatar
Jim Dawson
They were a pain to install but after they're done they work well and look way better than the two alternatives.
Old Jun 21, 2009 | 05:53 PM
flyingace's Avatar
flyingace
For what its worth, to anyone reading,
The 09 version is a lot easier to install. I've had/done both, and yea, prior to 09, they are a huge pain in the butt.
Old Aug 11, 2009 | 10:38 AM
AndrewMichaelZ's Avatar
AndrewMichaelZ
My bad, I put this on another thread, but this one is more recent and it is really where my question belongs:
Bought the HD Deflectors and have installed the left side no problem. I've got an 07' Street Glide that has Bassani True Duals and a Power Curve. Anyone have tips on getting the right side deflector on. The top screw is blocked by the rocker top and the bottom is blocked by the power curve. Do I need to remove the power curve?
Old Aug 11, 2009 | 11:30 AM
cmhfguy's Avatar
cmhfguy
Installed them on my '09 Eglide two days ago. Took my time, planned it out, laid a towel immediately under the holes the clips and screws go in to catch anything that might fall. The towel prevented anything that dropped from falling down into the hard to get at places. Take your time and plan and it will get done with minimal fuss.
Old Aug 12, 2009 | 07:07 AM
Youngeezer's Avatar
Youngeezer
I've had mine on for a while now, and they do make a big difference, so I'm glad I installed them. If I had it to do over again, though, I'd go buy some shorter bolts with a standard hex head on them rather than the allen style bolts. That way you could get a ratcheting open end wrench on them.
Old Aug 12, 2009 | 09:55 AM
xmeter's Avatar
xmeter
As I am reading this I am laughing inside. I thought maybe it was just me. I believe I made up some new words when I put them on my 08....
Old Aug 12, 2009 | 06:59 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
!$%%@@^@@$%^&*^)%$*# spring clips. I lost both of mine. One's in the bike somewhere, the other is somewhere in the garage. I heard it hit but can't find it. Went to the hardware store and got some new ones. They look to be better designed and should hopefully go on easier.
Old Aug 12, 2009 | 07:14 PM
Trey Hogger's Avatar
Trey Hogger
Well, I'm glad I wasn't the only one that thought these were a lot of trouble that should have been simple. Anyway, in the time I've had them on I notice a good difference - not near as uncomfortably hot on my thighs as before. I'd like to have done something to actually make the bike run cooler, but just shielding from the heat helped a lot.
ralfie
Apr 11, 2014 01:17 AM
SlickDeluxe06
Mar 2, 2014 07:52 AM
rojuwi
Oct 26, 2012 10:53 AM
stbob07
Sep 18, 2011 04:52 PM
osirisdean
May 15, 2011 11:06 AM
