Question for those using Adjustable Pushrods
Old Jun 16, 2009 | 10:07 AM
nemick's Avatar
nemick
Default Question for those using Adjustable Pushrods
For those of you using adjustable pushrods, how often, if ever, do you check the tightness of the locknuts?
Old Jun 16, 2009 | 10:30 AM
07RoadHawg's Avatar
07RoadHawg
I checked mine after the first 100 miles and they were still tight. Might be checking them at each oil change after reading that post about the rod shooting through the tube though... Sure couldn't hurt to make sure they are ok.
Old Jun 16, 2009 | 10:52 AM
petemac's Avatar
petemac
And don't forget to blue locktite them!
Old Jun 17, 2009 | 06:44 AM
Heathen's Avatar
Heathen
Check them every oil change-hope you were kidding on the locktite ?
Old Jun 17, 2009 | 06:50 AM
JustDennis's Avatar
JustDennis
After I installed mine on my RK, I never checked them unless I was doing some other engine work. The jam nuts seem to hold very well if torqued properly.
Old Jun 17, 2009 | 12:52 PM
nemick's Avatar
nemick
Does 15 ft lbs sound about right?
Old Jun 17, 2009 | 01:25 PM
Puttnutt24's Avatar
Puttnutt24
Can anyone tell me where I can find a good step by step explanation on how to properly adjust adjustable pushrods on the net? Preferably with illustrations.......Thx, Rich
Old Jun 17, 2009 | 01:47 PM
07RoadHawg's Avatar
07RoadHawg
Big Boyz has good instructions
Old Jun 17, 2009 | 01:56 PM
Puttnutt24's Avatar
Puttnutt24
Thx, apprecaite it...........
Old Jun 17, 2009 | 08:21 PM
FLAMED96's Avatar
FLAMED96
To adjust pushrods that you may no longer have the instruction sheets for or may have come in a bike when purchased, you can figure out the adjustments as follows.
The number of flats to turn the nut for proper pushrod adjustment can be calculated easily. First you have to find the number of threads per inch (tpi) on the adjusters. To do this simply measure 1 inch of threads and count them.
The tappet plunger moves aproximately .190" and the adjustment is in the middle or at about .100". To figure the number of flats for a .100" adjustment, use the following formula... number of flats=.100"/[1"/(tpi*6)]
For example, an adjuster turned 3 turns (18 flats) @ 30 tpi will make the pushrod .100" longer.
30tpi*6=180 (Threads per inch TIMES 6 = 180)
1"/180=.0055555 (1 inch DIVIDED BY the answer from above, in this case 180)
.100"/.0055555=18 flats (.100" is the amount of desired pushrod movement DIVIDED BY the answer from above .0055555 and EQUALS the number of wrench flats to obtain the desired adjustment.)
To further explain this....
tpi TIMES 6 gives the total number of wrench flats in 1" of the adjuster. 30tpi TIMES 6 wrench flats per thread EQUALS 180 wrench flats per inch.
1 inch DIVIDED BY the total number of flats (180) EQUALS the amount of travel for 1 wrench flat (.0055555")
Total travel desired (.100") DIVIDED BY the amount of travel per wrench flat (.0055555") EQUALS the number of wrench flats to achieve the desired travel (18 flats).
