Clearcoat Problem
Old Jun 16, 2009 | 08:24 PM
SteveM's Avatar
SteveM
Default Clearcoat Problem
I've got a vivid black 07 Ultra w/ 24,000 miles. I am meticulous about keeping it clean. While cleaning it after a recent trip of 1,200 miles I found 2 areas on the front fender where the clearcoat appears to be separating from the basecoat. Anyone had any experience with clearcoat problems or heard of anyone who has? Although my 2 year factory warranty has expired, I am in the first year of my extended 5 year warranty. I've heard and read that Harley doesn't cover paint under warranty anyhow. Here are a couple pictures of my problem. Any input is appreciated.
Old Jun 16, 2009 | 09:05 PM
Donnylee's Avatar
Donnylee
Thats not good! I think your on your own with it. Is it just the front fender?
Old Jun 16, 2009 | 09:13 PM
stro1965's Avatar
stro1965
Ouch! I better keep an eye on my vivid black '07 Ultra!
Old Jun 16, 2009 | 09:25 PM
trkmd's Avatar
trkmd
1st Gear
Unhappy I understand!
Same thing just happened to my 2007 vivid black ultra classic! Top of my saddle bag has some clear coat flaking... having to get a body shop to repair...wonder if motoco bought their clear coat products from China or North Korea???
Old Jun 16, 2009 | 10:19 PM
bigskyhd's Avatar
bigskyhd
That's just wrong. My sympathies. I've got a 2000 in vivid black base, and fortunately it still looks like brand new. Good luck trying to get the MoCo to cover it. THEY SHOULD!!! It's an obvious factory defect, and I'd fight that all the way up the ladder. Definitely contact one of the zone reps. PM me if you need a rep phone#.
Old Jun 16, 2009 | 11:14 PM
ky_ace's Avatar
ky_ace
I have to say... I'm not seeing what you're referring to. Can you get a pic up of you pointing to the defect?? The clear is baked on so I really don't see it just flaking off.
Old Jun 17, 2009 | 06:45 AM
jharanin's Avatar
jharanin
It's hard to see what you are trying to point out in the picture. There are several things that can be going on. First, is that the only place you see it? If that's the case it could be surface contamination on the base before clearcoating. If it's in other locations I would have someone check mil thickness to see if the correct amount of product was put on in the first place. If they didn't put enough clear on you could have delamination from lack of UV protection. In that location I don't think thats the case. I have an 07 as well and the paint looks fine...do some homework before you go to MOCO at least you'll have a leg to stand on. On automotive finishes you look for 4.5 - 6.0 mils from sheet metal up.
Old Jun 17, 2009 | 07:37 AM
rjmac53's Avatar
rjmac53
that's not good...keep us posted...
Old Jun 17, 2009 | 07:48 AM
Scorpion07's Avatar
Scorpion07
I see it clearly. It's odd how it's peeling in a uniform strip, almost like real bad paint prep?
My 07's OK so far....
Old Jun 17, 2009 | 07:49 AM
notlost_nc's Avatar
notlost_nc
Maybe some DOT 4 brake fluid has dribbled on down to the fender during servicing ?
