Mobile 1 15w-50 in primary?
Old Jun 19, 2009 | 06:34 PM
DougM's Avatar
DougM
I just completed my 1000 mile service and switched to Mobil 1 20w50 for the engine, Mobil 1 ATF for the primary, and Mobil 1 gear lube for the transmission. Everything seems to run more smoothly than before. Everything was $8-$10 a quart.
Old Jun 19, 2009 | 06:35 PM
backdoc_rider's Avatar
backdoc_rider
That's pretty much the setup I just switched to. Amazing difference. I'm sticking with that
Old Jun 20, 2009 | 12:07 AM
Gearhead3's Avatar
Gearhead3
I got some clutch slippage with my NT using German Castrol 0W30. Won''t ever do that again!! Only noticed it when in third or fourth gear under load, though.
Old Jun 20, 2009 | 11:23 AM
Gearhead3's Avatar
Gearhead3
On another note, you may want to check and see whether or not the Sportster guys are having any problems. If I'm not mistaken, their primary and crankcases are one unit. If there were any problems, I'm sure they would have found them by now.
Old Jun 20, 2009 | 12:46 PM
iclick's Avatar
iclick
Originally Posted by TheWhitedogg
That was me Iclick. When I had the clutch slippage I decided to switch to Formula 1 and I replaced the stock diaphram with the SE high perf diaphram at the same time. I have to believe the slippage was due to the clutch spring and not the oil. All is good now.
I didn't remember who said it or where I saw it. I'm still perplexed about why you had slippage with the stock spring when I haven't heard about others having that issue including me with a nearly identical setup. I asked the service mgr. at the local shop and he said the stock springs have not been a problem after cam changes in his experience. I would tend to just change the spring, but it should increase the lever tension. How does yours feel?
Old Jun 20, 2009 | 02:38 PM
jeff194's Avatar
jeff194
The thing that concerns me is that the Mobil 1 15w-50 seems to shear to a 30 weight oil in the crankcase, as documented by Skip in the oil section. So that kind of negates buying 5 Qts of it just to include the primary.
Time2Cruise
Oil Archive (no new posts)
16
May 18, 2011 09:33 AM
labou1
Oct 24, 2010 07:26 AM
third_left_eye
Jul 24, 2008 11:00 AM
baldjohnny
Jul 13, 2007 08:36 AM
Whiffleboy
Jan 28, 2007 12:47 AM
