Broken Drive Belt
We went with what the catalog says was the right belt. My original belt was 1.25" wide. Whats up with this? All we can figure out is the rear pulley must have been changed before I bought the bike.
Our delima... take the OEM belt back off and re-order a 1.25" belt and use the original pully that came off the bike, or try to find a 1.5" rear pulley? The indy is just shaking his head over this. Appologized up and down, but is leaving the decision up to me. Says he wont charge to take the OEM belt back off, because he should have measured it to begin with. This guy is a friend and I don't want him taking a beating over this.
To top it off, I had planned to ride with the FLA CREW today up to Solomons Castle, and all of a sudden I am not going to have a ride. Indy called his boss, told him the story, boss says I can take their Road King for the weekend.
Well I gotta tell ya, Im IMPRESSED with my luck to have such a great shop to do my work. l want to say thanks to "Big R Customs" here in cape coral, fl. Great bunch of people to deal with.
1. Clean rock particles from puncture.
2. Apply some JB Weld (epoxy) in the hole, smoothing it out on the outer area (smooth side) and removing the excess. Make sure it completely fills the puncture hole.
3. Apply some plastic wrap on the inner area (toothed side) and roll the affected part of the belt over the pulley.
Doing this makes the epoxy form to the shape of the belt and pulley.
4. Leave it in this position overnight or as long as specified in the directions for curing.
My old RK still has the original repaired belt on the bike today at 120k miles and the repair looks the same as it did when applied. I'm told that a puncture toward the edge of the belt may not be repairable, at least for the long term. In any case I would inspect the belt every time you clean the rear wheel, even if there are no repairs to check. You'll want to deal with a repair sooner rather than later.
It should be about a $500 job give or take depending on how many pulleys are replaced. That $1275 price had better include a lot of extra stuff or someone got seriously raped.
The 1 1/2" belt fits 2003 and earlier baggers. 2004 had 1 1/4" carbon fiber ( stronger) belt. Either the catalog was wrong (?), or the Indy read it wrong. 05 never had a 1 1/2" belt and your skinny pulley is stock.
