Broken Drive Belt
Old Aug 18, 2013 | 07:34 AM
  #31
Gregsenn's Avatar
Gregsenn
Stage I
I just crapped my belt yesterday. I drove 60 miles w no incident, parked at a gas station for 5 min, came back out, manually rolled my 2005 Road King backwards down the incline and then fwd into a pump area. I filled the tank, started, pressed down to first, release the clutch lever, and nothing. Looked down and my belt was on the ground.
$165 to get the bike towed, & $825 to fix it...
($410 was labor).... ouch.
I have only 19000 miles on the bike. The service dept at Sauk Prairie was excellent, but still hurts my "Wally Wallet"... I am a pretty smooth driver, and take great care in being mindful of parts/maintenance. (I don't ever hammer on my touring bike, so I therefore believe there was either a fault in the belt, or a stone magically jumped up in there while I was parked at KwikTrip in Baraboo???)
Old Mar 11, 2022 | 01:47 PM
  #32
Docmel's Avatar
Docmel
Most belt failures are caused by the wrong tension or measuring the tension incorrectly. (Too tight is the most common issue) Belts are FAR superior to chains If you have ever done any work to your bike that involved the rear axle (Tire change, changing brake pads, etc, you have to measure the belt tension as per the SM when done: MANY shade tress AND HD mechanics take shortcuts and just use an eyeball. The tool for measuring tension is cheap, available and easy to use (Takes about 30 seconds: I got an HD tool off ebay, $30
And yep, labor is extensive to change one out" The whole inner/outer primary and clutch has to come off
Old Mar 11, 2022 | 04:14 PM
  #33
Keithhu's Avatar
Keithhu
13 year old thread, fyi.
Old Mar 12, 2022 | 09:25 AM
  #34
Docmel's Avatar
Docmel
It is an old thread but still useful info
suiii15
May 16, 2012 08:12 AM
TexFordD
Mar 24, 2009 08:16 AM
00glider
11
Sep 26, 2007 03:42 PM
clayman
Oct 15, 2006 03:08 PM
DieHard
May 2, 2006 08:01 AM
