Fluid change tips
Old Jun 19, 2009 | 12:50 PM
rome304's Avatar
rome304
Default Fluid change tips
Decided to do my fuild change myself i have the service manual looks pretty simple. this weekend or next any tips appreciated there use to be a video link for this awhile back.
can i do this without a lift just using my chock? thanks for any tips ya boy rome.
Old Jun 19, 2009 | 12:55 PM
07RoadHawg's Avatar
07RoadHawg
The only reason I use a jack is to hold the bike upright for the primary service. Engine oil pan drains better (or my mind thinks it does) on the side stand.
I'm sure you've seen the tip about a 2-liter soda bottle for the oil filter. I personally use the folded tin foil method, but still manage to drip some. Oh well. Just follow the manual, no big deal.
Old Jun 19, 2009 | 01:14 PM
garyhendley's Avatar
garyhendley
Having the manual makes it easy-rdie safe
Old Jun 19, 2009 | 01:50 PM
backdoc_rider's Avatar
backdoc_rider
someone have pictures of the two liter soda bottle method? How to cut it and how to put it in. I made a mess changing my filter the first time I changed.
Old Jun 19, 2009 | 02:11 PM
VARDR's Avatar
VARDR
Use a platic zip lock bag to change oil. A lift is very convieniet ($80 at Harbor Freight). Need torque wrenches (in and ft). Need a belt tensioner guage for your belt. Finally, I marked the checklist with the pages of where it explains how to complete the task. Makes it go faster. Good luck
Old Jun 19, 2009 | 02:19 PM
Notgrownup's Avatar
Notgrownup
+1 on the Ziplock or the soda bottle...Whatever oil drips out i just prays some Brake cleaner in around the filter and cleans the oil leftover and it dries super fast...I use a little bit of pipe dope (liquid sealer) on the drain plugs...new o-rings...buy a bunch...Every time pour a little oil in the filter before putting it on...You should be fine with a chock. Have fun and enjoy it. Oh...don't over tighten the T27 torx bolt on the primary cover......
Old Jun 19, 2009 | 02:27 PM
hogbag07's Avatar
hogbag07
Don't over tighten the sump plug they will strip very easy
Old Jun 19, 2009 | 03:59 PM
rome304's Avatar
rome304
Need a belt tensioner guage for your belt. why do i need this to change fluids???
Old Jun 19, 2009 | 05:05 PM
jokerx's Avatar
jokerx
I'm sure he was assuming you were intending to do a full service...most folks say they're gonna change the oil and mean they're gonna do a service which includes more than just changing the fluids.
Old Jun 19, 2009 | 06:10 PM
watercop's Avatar
watercop
I use an old gear lube bottle cut in half to put under the oil filter. its a perfect fit. I have a piece of plastic tubing on it that extends to my drain pan. Have never spilled even a drop
I also strongly recommend using a torque wrench...a real pain if you strip one of the plugs
