Big Bore Kit - Do It Yourself?
Old May 18, 2006 | 11:54 AM
Bill918's Avatar
Bill918
Default Big Bore Kit - Do It Yourself?
I am considering doing a 95" kit, sending the heads out to be polished and ported, and doing a new cam. This will be done over the upcoming winter. I am not a wrench, but have done all the work and service on my bike so far. I've done work on the clutch, replaced cables,. In the past I've rebuilt carbs. , so I have limited experience. Is the big bore kit something I could tackle myself, or is specialized equipment and diagnostics needed? Looking at it it appears to be bolt on, but I know looks can be decieving. Anyone here do a big bore kit yourself? How tough was it and what is your experience level? any help and guidance would be appreciated....Thanks.
Old May 18, 2006 | 11:59 AM
bountyhunter's Avatar
bountyhunter
Default RE: Big Bore Kit - Do It Yourself?
Are you kidding, leave it to a pro with the proper tools!
Old May 18, 2006 | 12:09 PM
liltrk's Avatar
liltrk
I did mine and am very happy with the results. Everybody has different levels of competence/confidence with mechanical stuff, no offence to anyone.
You absolutely need a torque wrench and a manual. The cam bearings will require some special tools. I am not a trained mechanic, but have been wrenching on cars for a lot of years. Its not rocket science, but you need to be meticulous about every step.
Old May 18, 2006 | 12:11 PM
100thRK's Avatar
100thRK
I have to kind of agree with bountyhunter. I do alot of my own maintenance and have built many a V8 motor but I didn't do my motor as I just don't have the experience with them. I have a big bore, cams, heads, high compression motor with 8000 miles on it. Several long trips and not one problem yet. Glad I let a pro do it. My wrench has been building harley race bikes for 35 years. He even modified the harley HTCC heads for a little more omphhhh.
Old May 18, 2006 | 12:17 PM
lil_gmac2's Avatar
lil_gmac2
Your life is worth more then to try to save some bucks let the pro do it. Look on the bright side if it not right you can go back a holler at them. When was the last time you hollered at yourself.
Old May 18, 2006 | 12:23 PM
venture33's Avatar
venture33
I'm built too low to the ground. That project is way over my head. I've recently found an independent wrench (word of mouth refferals) who I'll have do any significant engine work for me. Good luck.
Old May 18, 2006 | 12:42 PM
liltrk's Avatar
liltrk
100thRK if you can build a V8 and make it run, you can build a Vtwin. Pistons, rings, lifters, pushrods, rockers, gaskets. There is no "magic" inside that little motor. All the same principles apply as a Chevy or Ford.
Old May 18, 2006 | 01:02 PM
eddybo69's Avatar
eddybo69
You can always try it and then take the box full of leftover parts to the dealership and have them figure out where they go. J/K I think anyone with the manual and some degree of mechanical ability and the proper tools can probably do it.
Old May 18, 2006 | 01:11 PM
Neckball's Avatar
Neckball
Yesterday...................
Old May 18, 2006 | 01:19 PM
Bill918's Avatar
Bill918
My desire to do this project is based more out of self satisfaction than wallet, just don't want to get too far in over my head.
