Heel- toe shifter
Old Jun 24, 2009 | 10:24 PM
heavy K's Avatar
heavy K
if ya want more room on the floorboards try ez shift and ez brake from florida. their shifter kit has extend shift arms front and rear which allow for plenty of floor board room. its a great upgrade. im also a life long heel shifter and wouldnt want it any other way. as far as loosenes its important to have the spline very clean and the bolt very tight and locktited...the locktite acts as a lubricant when tightening an allows you to get the bolt extra tight which is whats needed.
http://bellsouthpwp.net/e/z/ezbrake/index.htm
Old Jun 24, 2009 | 10:54 PM
mike5511's Avatar
mike5511
Like the heel shifter. I am long legged and I never have my feet tucked under me enough for the heel shifter to be in the way. Been thinking of looking into the floorboard extenders that move them out and forward 1 inch, Kury makes them I think.
Old Jun 24, 2009 | 11:06 PM
ranger56528's Avatar
ranger56528
I just put them(Kury) on my 01 EGC and the only issue is the break peddle,I can either go with a smaller pad or get a longer arm,not sure witch way ta go yet but its not a BIG issue just one to fix down the road.
Old Jun 24, 2009 | 11:40 PM
Potato_Potato's Avatar
Potato_Potato
Ditto on the Blue thread locker on the spline - also inspect it while you have it off.
Heel shifter was the first thing I took off the bike. I road home from the dealer pulled in my garage took it off and went for a very long ride.
Old Jun 24, 2009 | 11:54 PM
dabluesguy's Avatar
dabluesguy
I put the floorboard extensions on AND removed the heel shifter. My size 13's are lovin' it now.
Old Jun 25, 2009 | 03:33 AM
gunner11's Avatar
gunner11
Originally Posted by ndnguyd
Heel shifters suck. They take up all of the floorboard area.
It ' s obvious you don't see the purpose, for floor boards, put on extensions. newb.
Old Jun 25, 2009 | 06:33 AM
paguy's Avatar
paguy
First, the problem with heel/toe shifters has been chronic for years. With the importance of the ability to downshift, why Harley hasen't addressed this is amazing.
Second, A lubricate on the screw will help it seat better. People state loctite on the shaft and letting it sit overnight helps.
Third, new shifter arms will do if neither of the above don't work.
Four, changing the shaft can be a bear.
Thank you all for the input. There are other threads on this subject.
Old Jun 25, 2009 | 07:10 AM
emwolb's Avatar
emwolb
sorta like having two eight ball gear shift ***** in a stick shift chevy ain't it? i removed my rear one after i got the bike home from the dealership. definately isn't gonna be going back on. with size 14 boots, i need all the floorboard room i can get. already did the extensions, what a great idea that makes it more comfortable to ride.
Old Jun 26, 2009 | 08:27 PM
dorse's Avatar
dorse
6th Gear
Try rockerboards and eliminate shifter and brake pedal.
briggsmade.com
Old Jun 26, 2009 | 08:37 PM
davewear's Avatar
davewear
removing the heal shifter will void your warranty, i did it anyway.....
