Inner Primary Swap
Old Jun 25, 2009 | 04:17 PM
DADDYO's Avatar
DADDYO
Cool Inner Primary Swap
Is it safe to use an impact wrench to break the compensator & clutch hub nuts loose during the tear down?
Old Jun 25, 2009 | 06:31 PM
rsavage's Avatar
rsavage
If I remember correctly and it's the same as on softails and the b engine, you shouldn't use an impact wrench on the compensator to loosen as it could damage charging system. I believe it is okay on the clutch to loosen. I don't have my new service manual yet so can't tell you for certain.
Old Jun 25, 2009 | 07:44 PM
dawg's Avatar
dawg
Answered your visitor message with a PM. There are magnets stuck/epoxied on the rotor/stator assembly that could come loose from the jarring of an air impact. I've seen it done, but I wouldn't risk it. Just slip a piece of pipe or the handle from a floor jack over a ratchet to remove both nuts. Always has worked for me.
heavypic
13
Jun 14, 2021 05:53 AM
Steve On 3
Nov 8, 2020 04:48 PM
65panhead
Panhead
Feb 2, 2013 03:52 PM
wmflhtcui
Sep 9, 2012 06:30 AM
missouri traveler
Jun 24, 2007 01:08 PM
