Shift Peg Extender or Extended Shift Pegs?
Old Apr 9, 2010 | 08:31 AM
Retrop's Avatar
Retrop
I put two of the stock rubber shifter pegs together. I did put a couple of hollow steel spacers inside them before running a long bolt through both, Looks like a factory job. Since I had all the parts laying around, the cost was not much. If you didn't already have parts, the rubber shift peg from Harley would probably be the most expensive thing. Spacers and long bolt come from hardware store.
Old Apr 16, 2012 | 07:01 AM
BigGelvis's Avatar
BigGelvis
Resurrecting this thread from the dead! ( shows I at least attempt using the SEARCH function before posting.....lol)
Anyway, anyone else come up with solutions to this problem? I would like to see or hear them.
I would like to find some off the shelf parts that will extend the front shift peg out about 2 inches or so and allow me to KEEP the rear heal shift arm and peg.
Looks and function are important so looking for some ideas you big foot guys have come up with that looks clean and strong.
Old Apr 16, 2012 | 08:54 AM
DXHD $100's Avatar
DXHD $100
Great Idea I got a longer shoulder bolt with the same dia. as stock from an Industrial supply store(Fastenal). I used the Factory rubber then I cut the factory heal rubber to the lenght I needed.
Old Apr 16, 2012 | 10:09 AM
Pumba11's Avatar
Pumba11
Kuryakyn makes a wider shifter peg (Iso Longhorn) and a extra wide brake pedal. I have both on my bike and they work fine. The brake pedal is quite wide and my friends like to call it the '59 Caddy brake pedal. I rather like it. Others my find it too big for thier tastes.
http://www.kuryakyn.com/Products/146...rake-Pedal-Pad
http://www.kuryakyn.com/Products/614...ISO-Shift-Pegs
Old Apr 16, 2012 | 10:14 AM
hog-doc's Avatar
hog-doc
Nobody markets a 2" extended shift peg, i made one for my dad, just need to find someone with a lathe that can turn down a section of aluminum to match the diameter of the shift peg you have, thread both ends and bolt it up.
Old Apr 16, 2012 | 10:18 AM
BigGelvis's Avatar
BigGelvis
I have that brake pedal extender on order already. Since I can't find any floorboard inserts that I like for the 2012 limited yet, I think I'll be fine sticking with the OEM style brake pedal.
I do have the same problem with the brake as I do the shifter and I am sure this will help. I have been holding out as I HATE Kuryakyn chrome! But I do not see anything else on the market to extend the OEM brake pedal so I went ahead and ordered it
emperor wurm
Mar 15, 2018 05:02 PM
Sturgis67
Apr 14, 2015 02:26 PM
PKellyMc
Apr 25, 2008 06:57 PM
diggitydogg
Dec 9, 2007 03:09 PM
Lawdawg
Jul 15, 2005 05:54 PM
