Help with Saddlebag lights
Old Jun 27, 2009 | 01:48 AM
Casper's Avatar
Casper
Default Help with Saddlebag lights
I posted this in the Electrical/Lighting section but received no replies, maybe someone here will help.
I just bought a set of used saddlebag lights, HD Glo Lights....without instructions, where do they plug into?
I know it sounds simple, just trying to get a jump on installing them.
Thanks all
Old Jun 27, 2009 | 03:24 AM
Harleypingman's Avatar
Harleypingman
Stop by your local HD store and, when they aren't busy, give the parts guy the PN and ask him to print out the kit instructions. Also, the installation will include a service parts list for the kit so you can know if you have all the parts you need, and if not, what's missing.
Old Jun 27, 2009 | 03:46 AM
lowleveldriver's Avatar
lowleveldriver
are these HD lights? I did it. I did them not hard. like pingman said you can do that but in a nut shell, they mount under the tour pak.
*remove the tour pak liner
*under the the tour pak fwd lower corner should be a rubber bumper(remove it) mount the lights there
*now the lights should come with a splitter connectors
*The tour power source should mate with the splitter.
I hope that helps
you can PM me if you have more questions
Trey
Old Jun 27, 2009 | 04:42 PM
Casper's Avatar
Casper
I hope that helps
Trey
Thanks, but it's the saddlebags, not the tour box....
just wanted to know when the pigtails plug into...
Old Jun 27, 2009 | 07:20 PM
rockhard69's Avatar
rockhard69
They can plug into the acc plug just in front of the battery. You will probably need a y connector
Gunner E
2014-2024 Touring Models
Jul 1, 2019 06:39 PM
harley11
Apr 12, 2012 12:08 AM
akroguy
Apr 7, 2012 12:20 AM
2011BDSG103
Sep 4, 2011 03:27 PM
jackja25
Aug 12, 2010 12:08 AM
