Starter Problem 07 FLHTCU
Old Jan 22, 2010 | 07:50 AM
shortride's Avatar
shortride
I had the same thing happen on my '06 Goldwing when it was only 6 months old. I was convinced the battery was good because I tested the voltage and charging system. The only problem was, I could not test the cranking power. After having the battery load tested I found the battery was bad and had it replaced under warranty.
Don't ever assume because the charging system is working and the voltage is good that the battery is ok.
Old Jan 22, 2010 | 08:05 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Thumbs up Another good thread and reminder
Because of this forum and this thread specifically, some time back I had this very issue. Starter bolts only finger tight...WTF? I found the problem when I heard an awful noise from the starter then nothing....remembered this thread and thought I'd just check. Sure nuff, tightened to Darren's torque specs. No more problems.
Old Jan 22, 2010 | 08:48 AM
Our07Ultra's Avatar
Our07Ultra
I know what I will be doing when I get home tonight...
Crown and Ginger....inspect started bolts. Obviously a one hour job.
3 minutes to inspect and adjust if needed...
57 minutes to enjoy a nice beverage and quiet time in the garage!
This place rocks!!
Old Jan 22, 2010 | 06:33 PM
brandaven's Avatar
brandaven
Stage IV
Default Update
I found that the clicking wasn't my starter the whole problem was the copper L bracket that mounts onto the battery was loose and not making contact. I tightened that up and have had no problems. Now i have a brand new starter that I picked up on Ebay as a backup if i ever need one. Hope this helps
Attached Thumbnails Starter Problem 07 FLHTCU-p7086144.jpg   Starter Problem 07 FLHTCU-p7086141.jpg   Starter Problem 07 FLHTCU-p7086143.jpg   Starter Problem 07 FLHTCU-p7086145.jpg
Old Jan 31, 2011 | 01:10 PM
Outlaw7x77's Avatar
Outlaw7x77
I took out the starter, cleaned the flange mating surfaces, it did look like there was a bit of corrosion built up. Put the starter back in and still nothing.
Last edited by Outlaw7x77; Feb 13, 2011 at 11:11 AM. Reason: To cover up what an idiot I was.
Old Feb 19, 2011 | 12:15 AM
Outlaw7x77's Avatar
Outlaw7x77
Default FOB BAttery is cause
Went back and changed the battery no my FOB. Victory! I have two FOB's...both batteries were dead! Lots of trouble to find that out. Make Certain the FOB battery is good...then start troubleshooting.
Rick L
Electrical/Lighting/Alarm
Jun 10, 2018 09:51 PM
garystaven88
Oct 25, 2015 11:39 AM
ss90
Jan 16, 2010 08:04 PM
Beauregard
Jun 2, 2009 08:29 PM
glide1996
May 28, 2007 01:39 AM
