Lowered my 06 Ultra Classic
I used the Lower kit sold by eGlide Goodies, (New Lowering Kits for Electra Glides, Road Glides and Road Kings
Designed to lower the rear of your Electra Glide, Road Glide or Road King without affecting the shock angle. READ MORE HERE.)
Thes are not some piece of crap you find on Ebay, they are of great quality and CNC Machined form 7075-T6 Aluminum and
Black Anodized. The fitment was right-on.
I chose to ignore the warning that says your better off for two up ridding to use the 1 inch kits, I measured the travel I have and believe there is plenty even after lowering. I do ride two up a lot and if guys can use the 11.5 inch progresive shocks then why notlower it 1.5 inches.
For those of you who are on the fence about to lower or not to lower I would say lower it.
I am 6 ft and 208lbs and after the 45 minute job to install this kit and adjust the drive belt I went for a 100 mile ride; I hit a few good bumps and went in and out a few drive ways and had no ill effects.
I am running the stock air shocks with 12lbs of air in them; I put 18lbs in and put a 140lb passenger on and road a bit around town and still no ill effects.
Those of you that feel you are sitting on your ride and feeling like your titling forward as apposed to sitting down in the saddle and leaning back I strongly suggest you give this a try.
Bruce
I went with the 2 1/2" R.U.B. lowering kit found on EBAY - AWESOME!!!!! One hour easy install. BTW - 6 feet / 250#.
Like having a new bike - feet really planted on the ground now. Lowered the center of gravity significantly. FEELS GREAT.
I can do oil changes, spark plugs, distributor cap and rotor...... basic stuff. Never seen a piston in 50 years.
The job will be a thousand times easier with a motorcycle jack - pic below.
Jacked it up - and removed shock bolts (top/bottom) one at a time on each side - put on the kit and rebolted.
No need to adjust anything except air pressure.
BUT these other guys are right - even at max pressure, you will bottom out (scape fender) on big dips and bumps.
I go 250 and the OL goes 200 - and I can ride fine 95% of the time - the fender scrapping is just noise period.
The lowering kit is a breeze to install - just follow directions and get some pics from the guy to help out GGhijr1@aol.com
[IMG]local://upfiles/5166/68C65252789A425BA92E0C50C187C5A2.jpg[/IMG]
