Hey folks, I've heard that some folks ditch the Torx t-27 and go with aftermarket chrome allen bolts.
This sounds good to me.
Where should I start looking?
Thanks.
Ebay
zanottis if you get the part numbers..
the local dealer.....
any online dealer (again part numbers help)
look in the h/d accessory catalog.
Look at www.harleydavidson.com under accessory's
need any more ?
I suggest you look at stainless allen head capscrews from just about any GOOD hardware store. Just take in one of the old screws and match it up with the new ones.
there is a problem with the stainless screws if you go that way. the kind you'll find at the hardware store work great for applications that don't require any stress, but they're not even as hard as grade five, the stainless ones anyway. i just bit the bullet and got the harley ones, and in the long run, it costs about the same as some generic type of stainless screws that are soft metal, by the time you're done.
I went with stainless steel - my experience with the chrome ones was that the chrome gets messed up from the wrench and then rusts. I found all except the longest ones at Ace Hardware.
