Question about error codes
Old Jul 1, 2009 | 06:36 PM
MarkM's Avatar
MarkM
Question Question about error codes
If you unplug the wiring harness from the ECM, will that clear stored error codes? Reason I'm asking is that I had a code for the crank position sensor. I unplugged the wiring harness and was going to troubleshoot from there according to the manual. But I took a look at the connector under the bike and found it loose. After fiddling with it, I put everything back together and fired the bike up. The code was gone now. I'm just wondering if it got cleared by me fixing the connector, or if that happens when you remove power from the ECM. Thanks.
KennyPowerz
General Topics/Tech Tips
Jun 6, 2018 10:30 AM
Aburton4
Nov 5, 2017 04:48 PM
coachchris
May 9, 2011 11:42 PM
KumaRide
Aug 6, 2009 09:28 PM
MarkM
Jul 1, 2009 06:42 PM
